95 D16 timing belt and water pump help.
Old May 3, 2007 | 08:09 PM
CRXhoopty_pimpin's Avatar
Default 95 D16 timing belt and water pump help.
Okay before I get slammed I am searching as we speak but can't seem to find it.
I just put the head back on my motor(95 D16).
What do I line up the crank to and what do I line up the cam gear to in order to put the timing belt on properly?
And how do I get to the water pump to replace it before I do all this??
Any write ups on here????
Thanks in advance.
Old May 3, 2007 | 08:15 PM
suspendedHatch's Avatar
Default Re: 95 D16 timing belt and water pump help. (CRXhoopty_pimpin)
You line the cam and crank up to TDC. If you're good, you wont move them while changing the belt and pump, so you wont have to mess with them at all.
The pump is pretty simple once you have the timing belt cover and belt off. It's just a couple 10mm bolts.
The only difficult things I can think of about changing the belt are 1. moving PS stuff out of the way, 2. moving AC stuff out of the way (oh wait, that's why I deleted AC and PS), and 3. you have to unbolt that one engine mount enough to slip the timing belt out.
Change the alternator belt out while you're in there. Maybe replace the cam seal and valve cover gasket as well.
There is no better writeup than the repair manual. Either download the Helms or buy the Haynes.
Old May 3, 2007 | 08:18 PM
Default Re: 95 D16 timing belt and water pump help. (suspendedHatch)
Thanks for the info.
Yeah there is no power steering or AC on this thing.
I already found a write up for doing this here on the forum.
I just needed a picture so I could see what I'm up against.
I've never done this stuff to a D series before.
Which timing mark on the main drive pulley is TDC?? When standing in front of the car looking down on the pulley there are 2 notches close together, one of which is white. Then about an inch lower ont he pulley there is a set of 3 notches one of which is red.
there are 2 sets of marks,
Looks easy enough.
Thanks again.
Modified by CRXhoopty_pimpin at 9:29 PM 5/3/2007
dj-t
Feb 20, 2012 07:13 PM
5.56
Jun 17, 2009 05:19 PM
SmYrE
Jun 4, 2009 03:42 PM
supracrx
Feb 17, 2008 09:06 AM
zracer240
Aug 1, 2005 10:07 AM
