Strut bars?
Old May 3, 2007 | 05:31 PM
iceman7329's Avatar
Default Strut bars?
I wasnt sure where to put this so here it is.
I got a set of strut bars cheap enough for me to buy them. There are used so no instructions, doh. Here is a pic, can someone tell me where/how to install them correctly? Thanks
Old May 3, 2007 | 05:35 PM
hondaboy4life's Avatar
Default Re: Strut bars? (iceman7329)
uhh...?
alright well if you just look at the top of your suspension (where it mounts to the shock tower) you will see there are two nuts...undo them, put the strut bars over the studs, then fasten the nuts ontop of them... As for the c pillar bar, if thats what it is, then undo the bolt keeping your seatbelt like top point onto ur car, and then put the cpillar bar moutn there and use that bolt. IF its a lower tie bar put it in between where ur rear lower lcas go to ur frame.
Old May 3, 2007 | 05:37 PM
doood's Avatar
been there done that
Default Re: Strut bars? (hondaboy4life)
those look like a rear/front strut bar and rear lower tie bar. when installing strut bars it's easier if you have the tires off the ground.
Old May 3, 2007 | 05:39 PM
russlan44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 &raquo;</TD></TR><TR><TD CLASS="quote">I wasnt sure where to put this so here it is.
this one looks like it goes to rear bottom
this one rear in trunk
and this one is front tower check the measurments also
correct me if im wrong
Old May 3, 2007 | 05:40 PM
amej8's Avatar
In the first picture, the top one is the rear upper strut, 2nd is the front upper strut, last is the rear lower tie (most likely).
To install them, remove bolts, put on bar, put bolts back on @ specified torque specs for those bolts.
Old May 3, 2007 | 05:43 PM
iceman7329's Avatar
Default Re: (amej8)
I know how the front will go. Anyone got a pic of the rears?
Old May 3, 2007 | 05:44 PM
amej8's Avatar
You'll have to cut into the plastic or the carpet (whatever is covering the shock tower) and it will be exactly like installing a front upper strut bar.
dao_yaj's Avatar
if you look at the dtrut, you will see where they go
Old May 3, 2007 | 05:45 PM
Eran's Avatar
HT White Ops
Default Re: Strut bars? (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote"> correct me if im wrong </TD></TR></TABLE>
You are.
Rear lower tie bar (worthless)
Front Strut Bar
Rear Strut Bar
iceman7329's Avatar
Default Re: (dao_yaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dao_yaj &raquo;</TD></TR><TR><TD CLASS="quote">if you look at the dtrut, you will see where they go
Good, kinda what I figured.
Old May 3, 2007 | 05:46 PM
iceman7329's Avatar
Default Re: (amej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 &raquo;</TD></TR><TR><TD CLASS="quote">You'll have to cut into the plastic or the carpet (whatever is covering the shock tower) and it will be exactly like installing a front upper strut bar.</TD></TR></TABLE>
So it will run through the inside of the trunk correct?
Old May 3, 2007 | 05:48 PM
amej8's Avatar
Default Re: (iceman7329)
So it will run through the inside of the trunk correct?</TD></TR></TABLE>
Yes. But it will run above the floor, probably 4-6 inches so if it's a grocery getter or you have a lot of things in the trunk, be prepared to have that bar in the way. It doesn't sit all the way towards the seat either.
4EN[sic]'s Avatar
I tried to put my new rear strut tower bar on and it wouldn't fit. I was pissed. Then I figured out to jack the back up so the wheels are off the ground and it fit like a charm. Might be the same for the front too.?...
Old May 3, 2007 | 05:50 PM
iceman7329's Avatar
Default Re: (amej8)
Yes. But it will run above the floor, probably 4-6 inches so if it's a grocery getter or you have a lot of things in the trunk, be prepared to have that bar in the way. It doesn't sit all the way towards the seat either.</TD></TR></TABLE>
Ok, my subs are in the way. Its time to build a box flush in the floor where the spare should go anyways.
Thanks guys.
Old May 3, 2007 | 05:52 PM
iceman7329's Avatar
Default Re: Strut bars? (4EN[sic])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4EN[sic &raquo;</TD></TR><TR><TD CLASS="quote">]I tried to put my new rear strut tower bar on and it wouldn't fit. I was pissed. Then I figured out to jack the back up so the wheels are off the ground and it fit like a charm. Might be the same for the front too.?... </TD></TR></TABLE>
Yep, probably going to be the same for the front.
termite1r
Apr 24, 2013 09:17 PM
EM2_Kid
Honda Civic (2001 - 2005)
33
May 16, 2008 06:00 PM
halcyon026
Mar 30, 2006 05:04 PM
kenjief8
Dec 30, 2004 06:59 AM
mickey513
Apr 30, 2003 03:31 AM
