d16y8 question
Old May 3, 2007 | 03:40 PM
EJ8 Kenobi's Avatar
Default d16y8 question
Well I'm installing some aftermarket gauges, oil psi and water temp..
My question is what is the bolt to the left of the oil filter? Can I plug my oil gauge into this? If you guys don't know what bolt im talking about I can probably take a picture.
Old May 3, 2007 | 04:41 PM
EJ8 Kenobi's Avatar
Default Re: d16y8 question (EJ8 Kenobi)
anyone know?
Old May 3, 2007 | 05:41 PM
HXvtec's Avatar
you talking about the bolt to the top of the oil filter?
Old May 3, 2007 | 07:04 PM
EJ8 Kenobi's Avatar
Default Re: d16y8 question (HXvtec)
It might be above the filter but Its to the left
Old May 3, 2007 | 07:10 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi &raquo;</TD></TR><TR><TD CLASS="quote">It might be above the filter but Its to the left</TD></TR></TABLE>
It's your oil pressure sensor, and yes its where your wire goes for your gauge.
Old May 3, 2007 | 08:06 PM
EJ8 Kenobi's Avatar
Default Re: d16y8 question (1995Civic)
I thought the sensor had a plug and wire on it? or , was I reading that info for a B series? This looks like a large bolt.
Nice avatar lol
Old May 3, 2007 | 08:22 PM
SpeedoKing's Avatar
pics would help a lot
Old May 3, 2007 | 09:18 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi &raquo;</TD></TR><TR><TD CLASS="quote">I thought the sensor had a plug and wire on it? or , was I reading that info for a B series? This looks like a large bolt.
Nice avatar lol</TD></TR></TABLE>
http://www.theoldone.com/articles/oilpressure/
Everything you need to know on this topic
...thank you, i like my avatar
Old May 4, 2007 | 04:20 AM
EJ8 Kenobi's Avatar
Thanks man, I'm gonna give that a go today and let you guys know how it turns out.
Any places on the block or head I can install the water temp probe besides the stock location?
Old May 4, 2007 | 07:13 AM
EJ8 Kenobi's Avatar
Well I'm not sure what that bolt was. I found the sensor just right above the filter. Now the question is, how do I remove it? Feels like a rubber shield tightly seals it.
Old May 4, 2007 | 04:28 PM
EJ8 Kenobi's Avatar
bump
Old May 15, 2007 | 07:58 AM
EJ8 Kenobi's Avatar
I've spent the last week getting the front end installed so I pushed this project to the side, but I took some pictures with my phone.
so how do i remove the sensor?
Old May 15, 2007 | 09:50 AM
1dumbscreenname's Avatar
the sensor should just pull out, mine did. and leaving the sensor to the side is ok, that wont throw any cel.
Old May 15, 2007 | 09:53 AM
Crazydave's Avatar
Default Re: d16y8 question (1dumbassscreenname)
the rusty bolt is a water drain plug ... to drain water from the block
the oil pressure switch plug pulls off....
it's a little hard to do, but it will just pull off
grab it really tight on the skinny part (or use some pliers)
Just dont rip the wire out of the plug
tomu06
Jan 27, 2008 02:29 PM
nuttybumpo
May 30, 2007 04:18 PM
conker
Feb 21, 2006 07:49 AM
JamesQ
Oct 7, 2004 03:59 AM
95hatchfire
Sep 29, 2004 10:34 PM
