For those grinding, or thinking about replacing synchro's.
I've been using Honda MTF from the very start yet this is the second time my 3rd gear assembly is crunching. I guess I can't shift for nuts. Very good illustration nonetheless. Cheers!
I've always used Honda MTF, however after some hard driving to the expo I found out that my 5th gear synchro also is junk. Oh well it's covered under warrenty, I figure now is a good time to put in a clutch.
All work was covered under warranty.
The 5th gear syncro assembly and reverse idler gear were replaced.
****... i guess i should try another dealer...
You should try another dealer.
Make sure you explain the problem as being gradual.
Ask lot’s of questions as to what could cause such a thing.
They’ll hopefully comment on the poor quality of Honda synchro’s.
Then they’re trapped.
I switched over to a sythetic gear oil, and it has all but gone away, ACURA is tellin me two weeks until they can get it in so I had to do somethin as its my daily driver.
mk818
Aug 27, 2012 08:37 AM
