How do i build to handle boost?
Old May 3, 2007 | 09:41 AM
Vaw7er's Avatar
Default How do i build to handle boost?
This is sort-of a continuence on my Turbo D16 or swap debate post... if i decide to Boost my D, what steps can i take to insure that my Z6 can handle 10psi daily and 15psi plus a 50 or 75 shot at the track? I was told to Sleeve and deck it, then get forged pistons and eagle rods... any opinions?
Old May 3, 2007 | 10:12 AM
doood's Avatar
been there done that
Default Re: How do i build to handle boost? (Vaw7er)
forged rods and pistons
adequate fuel system
proper tune
Old May 3, 2007 | 10:34 AM
ekb16's Avatar
sleeved the block for one, aftermarket turbo pistons and rods, send the crank out to have it balanced/micropolished since its already out of the motor. new fuel pump depending on how much your boosting, size your injectors correctly so you dont starve the engine and some really good tune
Old May 3, 2007 | 10:45 AM
chris61988kb's Avatar
Default Re: (ekb16)
Id also do cam shaft and gear, maybe replace the springs in ur motor, fuel pump, honda data or something of the sort, clutch and flywheel, id get a racing radiator and fan since ur boosting, probally need the room, and since ur juicin, help keep the heat down which will help keep your stuff in better conditon. and then pretty much what everyone else said to make it run safely.
Old May 3, 2007 | 10:47 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (chris61988kb)
Valves, springs/retainers, ARP head studs, pistons, cams.
You know, go fast stuff. And "hold my engine together" stuff.
mcgee*
Jan 24, 2007 04:16 AM
altz
Feb 25, 2006 06:30 PM
99teggsr
Jun 21, 2003 12:20 PM
JICsube
Jan 18, 2003 11:42 AM
fast[R]
Apr 17, 2002 02:50 PM
