Fuel Line Mounting Stud
Old May 2, 2007 | 10:01 PM
gotboost562's Avatar
Default Fuel Line Mounting Stud
How hard is it to remove the fuel line mounting stud from the stock fuel rail? I plan to upgrade to stainless fuel lines and would like to use the an to metric adapter vs. the an to banjo fitting. This is on an ITR motor in an EK. Thanks in advance.
AN to metric:
AN to banjo:
Old May 3, 2007 | 07:08 AM
Default Re: Fuel Line Mounting Stud (gotboost562)
No one here has removed or tried to remove the mounting stud?
Old May 3, 2007 | 08:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboost562 &raquo;</TD></TR><TR><TD CLASS="quote">No one here has removed or tried to remove the mounting stud?</TD></TR></TABLE>
Old May 3, 2007 | 08:45 PM
iceman7329's Avatar
How hard can it be to place a wrench on it and turn?
Old May 3, 2007 | 09:06 PM
Default Re: Fuel Line Mounting Stud (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 &raquo;</TD></TR><TR><TD CLASS="quote">How hard can it be to place a wrench on it and turn?</TD></TR></TABLE>
Where are you going to put a wrench? Once the nut is removed there is the stud remaining with only threads. You would have to use vice grips or similar to remove the remaining stud.
I found this pic courtesy of -EH3-:
Old May 3, 2007 | 09:07 PM
iceman7329's Avatar
Hmm, soak i with PB blaster and use vise grips. It will come out.
Old May 3, 2007 | 09:49 PM
SiYouLater's Avatar
Make sure you have a lot of time to do this. Might be a lot of down time.
Old May 3, 2007 | 10:01 PM
CarbonizedDX's Avatar
Default Re: Fuel Line Mounting Stud (SiYouLater)
Could try to double nut it. Spin on one nut and then spin the second one on after it, tighten second on down while trying to loosen the first then use the first nut as the removal wrenching point.
Another option would be to get a second oe fuel rail or aftermarket unit and do the swap out with less risk of leaving your stranded.
Old May 4, 2007 | 07:45 PM
Default Re: Fuel Line Mounting Stud (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">Could try to double nut it. Spin on one nut and then spin the second one on after it, tighten second on down while trying to loosen the first then use the first nut as the removal wrenching point.
Another option would be to get a second oe fuel rail or aftermarket unit and do the swap out with less risk of leaving your stranded.</TD></TR></TABLE>
I was thinking of trying the double-nut trick. I would assume the outer nut has the same thread and pitch of 12mmx1.25?
raidacaipo
Sep 12, 2008 02:31 PM
mixmastermatt
Feb 5, 2007 11:07 AM
BOOSTED_JDM_DB8
May 15, 2006 06:49 PM
NsX_CrX
14
Jan 16, 2006 06:25 PM
huge230
Jan 2, 2006 11:23 AM
