Car drifts to the right under acceration
I lowered my car and had it aligned and when i lowered it i noticed that i ripped the cv boot while doing it and now after the alignement and before the alignment the car drifts to the right under acceration. It doesnt pull or anything while im just cruising but when i give it gas it goes over to the right. i think that its the cv joint, but wanted to run it by you guys.
it wouldnt be from the cv joint. i say check your tires and recheck alignment. i once did an alignment on a car and it did that to me but the rack was sliding, check the bushings.
I just want to know if the bad CV joint would be the cause of this?I am going to repalce it anyway and i just wanted to know if there was anything else that might cause this so that i can get it fixed.
Note: The car is in perfect alignment.
hmm.. thats a head scratcher. did you lower it yourself? was everything put back on tight? never really heard of that problem, but like i said except for that one time this car had bad rack and pinion bushings.
check your front lower control arm bushings i had the same problem on my and the bushing on the lower control arm that bolts to the front subframe was shot i just replaced thar bushing and it was a nigth and day diference.
jrap1243
Oct 21, 2007 12:26 PM
