Problems w/ Sync 200??
Old May 1, 2007 | 05:13 PM
TurboSI56's Avatar
Default Problems w/ Sync 200??
While I was welding steel today, my machine would start up w/o argon. I can hear it click when I hear the pedal but sometimes the gas won't start w/ the arc. Any ideas?
Old May 1, 2007 | 08:22 PM
1 2 NV's Avatar
Default Re: Problems w/ Sync 200?? (TurboSI56)
mine does this periodically. i just shut off the argon and purge the system then hook it up again and all seems better. for me this happens mostly when i leave the gas on and it pegs the guage. dont know why, couldnt explain it but purging the system works for me. in fact had to do it yesterday.
Old May 1, 2007 | 08:52 PM
bamf3000's Avatar
Default Re: Problems w/ Sync 200?? (1 2 NV)
bump for more replies on this matter.
Old May 1, 2007 | 09:19 PM
TurboSI56's Avatar
the crappy thing is it's never done it before, tomorrow i'm going to call phoenix welding supply and see what they have to say. I'm guessing more then likely a relay could be going out? or maybe someone could have messed with one of the settings.
Things I checked:
postflow - auto
purged the lines
swapped tungsten (someone had lanthana 1.5 "grey" in there, not sure if thats good or bad or matters) back to red.
swapped gas bottles
cleaned everything thoroughly, re applied ground cable.
any other ideas?
Old May 2, 2007 | 05:14 AM
dave@passenger's Avatar
What does your regulator read? 0 CFH or 20+cfh? If its at zero screw your regulator adjustment in with your foot on the pedal until you get gas flow.
Old May 2, 2007 | 07:25 AM
TurboSI56's Avatar
Default Re: Problems w/ Sync 200?? (dave@passenger)
Its at about 17
Old May 2, 2007 | 09:59 PM
RCautoworks's Avatar
I have an issue where mine won't start an arc at times, usually when I first turn it on. I find if I touch the metal, then get off, then hit peddle its fine
Old May 3, 2007 | 04:32 AM
kranked91dx's Avatar
Default Re: Problems w/ Sync 200?? (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">I have an issue where mine won't start an arc at times, usually when I first turn it on. I find if I touch the metal, then get off, then hit peddle its fine</TD></TR></TABLE>
Yess mine does this on cold time, when it's cold in the garage (0 Deg C. ) I need to scratch start one time before the high frequency start work normally.
but I never had any gas flow troubble, it actually work everytime I need it.
Kranked
Old May 3, 2007 | 05:43 PM
dart2.2's Avatar
i had the same problem and took it to the repair man and i found out i had it wired wrong and it was only running at half the power. check your plug wiring.
01_ITR
Apr 5, 2009 07:55 PM
MR_FIX_IT
Apr 7, 2007 08:35 PM
menappi
Jun 21, 2006 04:01 PM
90babyblue
Dec 8, 2004 04:09 AM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
