EMISSIONS PROBLEM!!?
I took my car to get emissions done, I have a Brand New Cat on my car. Not more then 2 days old. 95 EG with JDM B18C Swap, DC headers with 02 Sensor and Skunk2 Exhaust.
I passed everything but the PPM Level...
NO PPM - Limit was 2400 and i got 3130
what does that mean anyone? and what can i do to fix it?
High NOx can be caused by high compression, high combustion temperatures, excess carbon buildup which in turn raises compression slightly....it can also be caused by a bad cat if all your other numbers look below avg. If you have EGR and it is diconnected or not working, you will have elevated NOx levels.
what are your other numbers, and what speed/rpm did they do the test under? Did you let the cat warm up really good before the test?
The Guy was stupid i guess, I pass Visual here are the Numbers, I am running Skunk2 ECU. NO HONDATA or anything else, I put a Brand new cat on my car the other day.
ASM2 Tailpiper Emissions Inspection.
15 MPH
<U>HC ppm</U> Limit is 183, the readin was 54 - PASS
<U>CO%</U> Limit is 0.73, readin was 0.01 - PASS
<U>NP ppm</U> Limit was 2400, Reading was 3130 - FAIL
25 MPH
<U>HC ppm</U> Limit was 200, reading was 32 - PASS
<U>CO%</U> Limit was 1.07, reading was 0 - PASS
<U>NO ppm</U> Limit was 2333, reading was 2834 - FAIL
15 MPH
25 MPH
Check over some maintenance items, like plugs, wires, cap+rotor, and PCV valve. It makes it difficult that there isn't an EGR system because EGR is pretty good at reducing nox, although you could always get adjustable cam gears and ramp the cams so the exhaust stays in there and cools the combustion chamber, but i'm sure that would throw your CO and HC through the roof haha.
Yea i just replaced the Plugs and Wires today, about to go change my oil here in a lil bit.. then run my car hard 30 mins before the test and then let it run while im waitin in line at the Emissions place.. what u think?
_F_Combat_F_
May 1, 2007 02:12 PM
