CV boots cracked, what else can i replace while im in there?
Old May 1, 2007 | 04:54 AM
ny153's Avatar
Default CV boots cracked, what else can i replace while im in there?
it is a '95 accord LX 4dr. the CV boots are cracked and i figured i'll just replace both axles. Does $100 labor sounds fair to do this job?
I found some driver and passanger side axles (#4202 and 4203) on feebay for $50 each, but they are not OEM: http://cgi.ebay.com/ebaymotors...QrdZ1
is it any good? or should i look for OEM replacement somewhere else?
What else can i replace while im at it. The car has over 120kmiles and the ride is kinda hard when i go over the bumps, i will do the shocks later though.
EDIT: question - do all '95 Accord LX come without ABS?
Modified by ny153 at 10:07 AM 5/1/2007
Modified by ny153 at 12:57 PM 5/1/2007
Modified by ny153 at 2:23 PM 5/1/2007
Old May 1, 2007 | 05:45 AM
soon2bdropped's Avatar
Default Re: CV boots cracked, what else can i replace while im in there? (ny153)
axle seals?
Old May 1, 2007 | 05:56 AM
The-Kid's Avatar
I just replaced my axles last week for both. I did it myself. The job is pretty easy. The process is like the "1997 Brake tuturial" plus a few more steps. You can do it yourself if you want to. Anyways, I got those cheapo ones from this parts shop, The joint don't even move. Buy from somewhere where you can inspect and test. Thats my suggestion.
Old May 1, 2007 | 09:14 AM
ny153's Avatar
Default Re: CV boots cracked, what else can i replace while im in there? (soon2bdropped)
dont they come in a kit with axle???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">axle seals?</TD></TR></TABLE>
Old May 1, 2007 | 09:56 AM
Heat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ny153 &raquo;</TD></TR><TR><TD CLASS="quote">...How do i find out if i have ABS or not? there are axles for ABS and non-ABS cars...</TD></TR></TABLE>
Here are the standard features for the ’95 LX:
http://www.edmunds.com/used/19....html
Note that there is no mention of ABS.
Here are the standard features for the ’95 EX:
which includes “4-Wheel ABS”. Note that the V6's had ABS and I'm assuming there was an LX V6, but you don't have a V6.
Also, my '99 LX doesn't have ABS.
Old May 1, 2007 | 10:14 AM
ny153's Avatar
Default Re: CV boots cracked, what else can i replace while im in there? (Heat)
thanks. so im going to order axles for non-ABS accord; i found a few brands like EMPI (most expensive $92 each), First Equipment Quality, ARC (least expensive $66) an CVU. Which one would you recommend? Here is the link: http://replacement.autopartswa...=true
shipping is free!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">Here are the standard features for the ’95 LX:
Also, my '99 LX doesn't have ABS.</TD></TR></TABLE>
Old May 2, 2007 | 07:55 AM
ny153's Avatar
so i have ABS if there is a ABS indicator right next to the fuel gauge, like it pictured here on 95 EX wagon:
at the same time this 95 EX sedan does not have an ABS indicator:
which makes me think that ABS was an option for EX models?
Old May 2, 2007 | 08:34 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The Accord EX (5th gen) had ABS. The picture shown, if it was an EX, may have had the instrument guage cluster replaced from a different trim model (e.g., LX, DX, etc.), but that person didn't swap the bezel from the original.
Old May 2, 2007 | 09:48 AM
TheMuffinMan's Avatar
He knows where you live!
I believe it was an option for the LX, EX's came with it
Old May 2, 2007 | 05:59 PM
Default Re: (TheMuffinMan)
no seal doesn't come with axle.. i madea mistake should've replace my seal when the axles was out now i gotta drop the axle back out..
Old May 2, 2007 | 07:46 PM
lowered94accord's Avatar
Default Re: (soon2bdropped)
the seals do not come with it unfortunately..and those things are a b**** to get out trust me...unless you get some sort of tool to get them out I dont really remember what its called...prying on it with a flat head doesnt work or at least it didnt for me...get the axles at autozone or advance if your not wanting to spend much..brand new axles from napa or somewhere like that will run you close to 300 dollars but they are well worth it...the ones at autozone will end up being about 200 maybe a little less..do it yourself its very very simple plus you'll get learning experience so you can do it the next time also
Old May 3, 2007 | 05:55 PM
Default Re: (lowered94accord)
what are u tlakin about? im asnwering ny153 questions about does axles come with seals and i said no.. and i wish i did mine when i had my axles out because its leakin now..
Old May 3, 2007 | 08:10 PM
1cpu's Avatar
see if there is a tone wheel when you take the wheels off to check for abs also when you turn the car on it does a self check of the lights of it lights up the u gots it
Old May 3, 2007 | 08:11 PM
1cpu's Avatar
i thin autozone has a life warranty on axels aswell, i think....
Old May 3, 2007 | 08:54 PM
i was just agreeing that the axles dont come with the seals and i was telling him that they are hard as hell to get out...and i highly doubt that autozone does lifetime warranties on their rebuilt axles...they know they are going to eff up after a while so why would they do that..they are old axles with new parts on them..so I highly doubt they have a lifetime warranty maybe a 3 month warranty or something..i dont know
Old May 4, 2007 | 10:09 PM
CBL9's Avatar
I boguht a passenger side axle for my cb7 yesterday at advanced for $69+ $25 Core, and lifetime warentee. $300^^^^^wtf are you talking about??
kcrumbie
Aug 16, 2012 08:09 AM
mjs13
Transmission & Drivetrain
May 6, 2011 11:34 AM
turbodailydan
Apr 18, 2010 12:40 PM
BLU CIVIC
15
Sep 15, 2009 12:08 PM
djkurious
May 20, 2009 04:07 PM
