proportion valve??
Old Apr 30, 2007 | 07:56 PM
kasperxtcy's Avatar
Default proportion valve??
i was just wondering if i would have to change the proportional valve if i do front and rear disc conversion on a ek? i got 99 GSR front and rear, arms and knuckles. i did the change over but whenever i break a little hard i feel the front end dip. also the rear rotor look like new with little wear.
Old Apr 30, 2007 | 08:30 PM
BlueIntegraBoy's Avatar
Default Re: proportion valve?? (kasperxtcy)
If you 96-00 Civic is not a hatchback, then you will need to replace the prop valve with one from a 96-00 Civic hatchback or 99-00 Civic Si.
Old Apr 30, 2007 | 08:35 PM
kasperxtcy's Avatar
Default Re: proportion valve?? (BlueIntegraBoy)
kool cause my ek is a hatch. just got done putting on the CTR lips, wing and grill will have pick up pretty soon. thanx again
Old Apr 30, 2007 | 08:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasperxtcy &raquo;</TD></TR><TR><TD CLASS="quote">kool cause my ek is a hatch. just got done putting on the CTR lips, wing and grill will have pick up pretty soon. thanx again </TD></TR></TABLE>
Bleed the lines again, as you may have air still in the lines.
On another note, Civics (and Integras) will have front brake bias even if there are rear discs.
kay_animation
Mid-Atlantic (Sales)
May 20, 2008 06:12 PM
primojoe20
Oct 22, 2007 02:20 AM
jetpilot
12
Jun 5, 2007 03:12 PM
kasperxtcy
Suspension & Brakes
May 1, 2007 02:01 PM
kay_animation
Aug 26, 2005 07:56 AM
