ZC = Not reving past 2000
Okay, well I took my car into the shop, and they gave me a crock of bull on how they couldnt fix it. But I doubt theye ven looked at it. Anyway, I am throwing a code 14. My car runs good, but at 2000 RPM it cuts out, fuel cutoff, or revlimiter feels like. We tried 3 GOOD ecus.. ECU is not problem. We are guessing its the coil or ignitor. Does anyone have any other suggestions? I am needing to get it fixed asap. Thanks.
home-limp mode? Injector box wiring? I can check that later on. Whats "Home limp mode" Anyway, I will mess with more stuff later on, I just need some more ideas it could be.
Well this all started when I was driving down the street and the car died.. It wouldnt start. I took the distributor cap off, and on the ignition module, one of the wires came off. It was running fine till then. I put that wire on, and it started right up. Now it wont rev past 2000 RPM, when at first it wouldnt rev past 3000. So its dropping. I am thinking the coil might be bad, thats why. ANy other suggestions? Is there a way to get it out of "limp mode" or safe mode?
Is the whole dizzy bad then? I have called a few shops today, and asked for there opinions on it, they all told me the dizzy sounds fried.
Also, how do you check to see if a TPS is in good working condition? How do you measure it, I think my TPS is bad too..
Well it was 2 things,a nd it should be fixed for good now.. First, my Idle Air Control vavle code was being thrown. So I messed with it a little, and I cleaned it out, it was frickon loaded with Carbon, maybe from my car running rich as hell. So I got some parts cleaner, and I cleaned it all out. Put it on, hooked it all up, ran past 2000. So I was happy aobut that.
Then my TPS code was being thrown, and my idle was way messed up. So the guy I sold my motor too, he sold me the thorttle body off it, 30 bucks, 5 more than I payed for the throttle body, it was convient, so I bought it, worked fine, other than the frickon whisteling noise it has.
So all is good, I remember last itme I made this post about everything running fine, the next day it broke down, haha, hope it dont happen this time.
memphiss13
Jan 5, 2002 09:18 PM
