EF Headlights installed, now need some help with wiring for fogs and sidemarkers too
Old Apr 30, 2007 | 12:45 PM
ef9robert's Avatar
Default EF Headlights installed, now need some help with wiring for fogs and sidemarkers too
Guys and Gals,
Was wondering if you can help me out with the wiring for the headlights, foglights and sidemarkers.
Thanks.
Old Apr 30, 2007 | 01:54 PM
91ed9's Avatar
Default Re: EF Headlights installed, now need some help with wiring for fogs and sidemarkers too (ef9robert)
the fog lights you can either wire to a switch of have them come on when your headlights come on
and the sidemarkers jsut splice into your blinker wires
Old Apr 30, 2007 | 02:43 PM
Default Re: EF Headlights installed, now need some help with wiring for fogs and sidemarkers too (91ed9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">the fog lights you can either wire to a switch of have them come on when your headlights come on
and the sidemarkers jsut splice into your blinker wires</TD></TR></TABLE>
lets see some pics of how the front end looks!
Old Apr 30, 2007 | 07:28 PM
ef9robert's Avatar
pics coming soon, just need to line it up right. I really need to get the headlights working since i cant drive the car @ night :-(
JDM Rear went on fine, going to sand it down and primer everything i can on sat.
Old Apr 30, 2007 | 08:12 PM
1989CivicSi's Avatar
Default Re: (ef9robert)
Taken from: http://www.efsource.net/tech/EF8FrontUSBumpSpt.php
So step by step:
A. Cut off old connectors
B. Splice all 3 black wires together
c. Splice red/green wire on harness to red/blue wire on headlight
D. Splice red/orange wire on harness to red/white wire on headlight
E. Repeat for other side.
F. Double check your work, and make sure the red wires do not touch the chassis or black wires at all bad things could happen.
G. Test them out! Make sure u have both high and low beams. (one thing to mention here is, if you used old bulbs they may be blown, mine was, the high beams on one side didnt work... So it one side works fine, and the other dosnt, switch bulbs and if the same side dosnt work its a problem with the wiring... If the other side dosnt work that used to work, its the bulb...)
As for the sidemarkers if you have a 90-91 wire them to the outermost corner lights. If you have an 88-89 you need to wire them to the bumper lights. Or be ghetto like me and slap on the frontend with 24 hours left before going back to school and wire to the corner lights anyways. Then use a relay system later for sidemarkers on all the time/blink when the turn signals go off .
Old May 2, 2007 | 07:26 AM
ef9robert's Avatar
thanks for the info!! Going to have it tonight!
Old May 2, 2007 | 07:41 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
after reading the writeup ...i am going to check if mine was done right.....thanks...
Old May 2, 2007 | 07:44 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9robert &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info!! Going to have it tonight!</TD></TR></TABLE> pics robert
DoubleEx
Apr 7, 2010 01:13 PM
PerkDA9
Lighting
Jan 11, 2008 05:50 AM
truevietluv636
15
May 4, 2007 09:02 AM
monalisa overdrive
Oct 24, 2004 01:29 PM
