Lighting HID/Xenon kits, Retrofits and Associated Topics
1 piece headlight wiring
Old Jan 10, 2008 | 06:36 PM
PerkDA9's Avatar
Default 1 piece headlight wiring
I got a DA and put one pieces in a couple of weeks ago, old headlights called for 9004's these call for 9007's. Headlights came with no wire harnesses. When 9007 are installed and lights are on: brights and lows are both on and its not lighting right, i put the 9004's back in and its not at all lighting the road right- its weak and lights the outsides, edges of the road. so now i'm running 9004's and my fogs at night to see. any help?
Old Jan 10, 2008 | 07:26 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 1 piece headlight wiring (PerkDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PerkDA9 &raquo;</TD></TR><TR><TD CLASS="quote">I got a DA and put one pieces in a couple of weeks ago, old headlights called for 9004's these call for 9007's. Headlights came with no wire harnesses. When 9007 are installed and lights are on: brights and lows are both on and its not lighting right, i put the 9004's back in and its not at all lighting the road right- its weak and lights the outsides, edges of the road. so now i'm running 9004's and my fogs at night to see. any help?</TD></TR></TABLE>
are these egay 1 pieces? i'm assuming so because jdm one pieces use h4h bulbs
what do you mean it's not lighting right? please don't run your fogs at night to substitute for standard headlights....it's not safe and makes you car look like a saturn
Old Jan 10, 2008 | 07:30 PM
Padawan's Avatar
Darth ModerVader
The 9004 uses a different wiring setup than the 9007. You will need to alter your wiring to the correct specs for the new bulbs.
The reason your lights aren't currently working properly is because you're running a 9004 bulb in a housing designed for 9007, so the focal points are incorrect.
Old Jan 10, 2008 | 07:35 PM
SuckMyDOHC's Avatar
Default Re: 1 piece headlight wiring (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean it's not lighting right? please don't run your fogs at night to substitute for standard headlights....it's not safe and makes you car look like a saturn </TD></TR></TABLE>
He's right. JDM DA headlights use H4H bulbs
Old Jan 11, 2008 | 05:50 AM
PerkDA9's Avatar
alrite thanks, they are ebay specials, had a friend back into me so cheap replacement, thanks again
hammerdgolfer
Jun 11, 2007 05:11 PM
b20integrapower
Jun 26, 2006 09:31 PM
PINKS
27
May 3, 2006 04:45 PM
klomast3r
Sep 6, 2005 01:52 PM
speedycivicgurl
Aug 13, 2004 07:21 PM
