OEM EK EX/SI Exhaust - measurement / length request
Looking for the length of an ex/si (EJ8/EM1) rear section (muffler and piping).
NOT the hatch!
A length from flange to muffler would be ok, but a complete overall would be best.
(Dont have to follow the curves, just straight length is what Im looking for
Reason:
I have this oem axle back that I want to put on, and Im thinking that the rear section is from a hatch (or something with a y7), because its several inches too short.
The rear piping (flange to muffler) is 15" or so...it probably needs to be like 18-19"
Just looking for confirmation
People look if there are pictures
(hopefully, I can get some help...)
Modified by pdiggitydogg at 5:00 PM 5/1/2007
NOT the hatch!
)Reason:
Well... I checked on both our '98 EX coupe and our '97 CX hatch. The exhausts are currently on the cars though, so the measurements might be off... I saw no one had helped you, so I figured I'd try.
I tried though.
Measurements are in a straight line.
Coupe/sedan (flange to muffler): 16"
Hatch (flange to muffler): 15"
I wish there was someone else who could confirm it.
I tried though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EKcivic »</TD></TR><TR><TD CLASS="quote">looks to confusing
...how is that confusing?
start the tape at the muffler and pull it back to the flange
I edited the picture anyways...
</TD></TR></TABLE>...how is that confusing?
lol... nice picture.
I measured both exhuasts the same way, only from the bottom since it's where i could reach with both cars on the ground.
Coupe exhaust was stock and hatch exhaust is Tanabe Super Medallion Hyper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">s'all good
the piping on both is the same, from what i know
(too lazy to compare the part #
(although, the em1 has a muffler tip)</TD></TR></TABLE>
Crap.. I just compared the part numbers for all piping plus muffler and no part number for the piping or muffler matches up between the EX coupe and Si coupe.
I just closed that window too.
Here's a comparision of part numbers of piping anf muffler.
PIPE A, EX.
96-98 EX - 18210-S01-A81
99-00 EX - 18210-S01-A72
99-00 Si - 18210-S04-A91
CONVERTER
96-98 EX - 18160-P2R-A00 (5MT) / 18160-P2R-A50 (4AT)
99-00 EX - 18160-P2P-A00
99-00 Si - 18160-P2P-A00
PIPE B, EX.
96-98 EX - 18220-S01-C81
99-00 EX - 18220-S01-A81
99-00 Si - 18220-S04-A92
MUFFLER SET, EX.
96-98 EX - 18030-S01-C80 / 18030-S01-C81
99-00 EX - 18030-S01-C81
99-00 Si - 18030-S04-C90
Modified by NOFX at 4:23 PM 5/1/2007
)(although, the em1 has a muffler tip)</TD></TR></TABLE>
PIPE A, EX.
CONVERTER
PIPE B, EX.
MUFFLER SET, EX.
In case anyone else needs this info in the future, measurements for my b-pipe (stock '98 EX pipe - P/N 18220-S01-C81).
From the cat to the resonator: 23 inches
Length of resonator: 16 inches
From the rear of the resonator to the *start* of the first bend: 13 1/2 inches
From the start of the first bend to the muffler flange: 28 inches
Image of measurements in case there is any misunderstanding.
Modified by NOFX at 5:47 PM 5/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">em1 b-pipe is the same exact length (at least using those measurements anyway
Still, its 2-3" shorter than it should be... Im positive its the rear section now</TD></TR></TABLE>
You can't get no action from the back section
)Still, its 2-3" shorter than it should be... Im positive its the rear section now</TD></TR></TABLE>
on top of that you ask about an engine/chassis combination that was never made... D16Y7 was available in the EJ6, not the EK9.
please try to be more conscientious.
mushroom samba
Aug 31, 2009 05:41 PM
Nicaraguense13
Jan 31, 2007 08:19 PM
boostedr
Oct 4, 2005 05:38 PM
