apex safc
Used Apex’I S-AFC
Painted black good condition comes with original manual, installation manual, and harness. Retails for 350
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the airflow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500-RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
160.00/obo
Modified by Yosshaa at 5:51 PM 5/7/2007
160.00/obo
wow thanks... i have one offer of 180 (sale pending) if that falls through i have another offer at almost 50 dollars higher then yours.
if things fall through and you add 50 bucks its yours!
