brand new caliper locking up
Old Apr 30, 2007 | 10:00 AM
g2_teg_'s Avatar
Default brand new caliper locking up
So i removed abs in my 94 EX coupe. to do that, i changed the master cylinder with one from a 90 LS integra. I also used the power booster from that same car. Then i got a proportioning valve from a civic or integra with rear disks w/o abs. Then i got the hard lines from a junkyard civic without abs. the hard lines i replaced were the two going from the master cylinder to the prop valve and the two going from the prop valve to each front caliper. then i used brand new stainless steel braided soft lines on all four corners.
so last week i had this problem: im driving down the road @ 40mph and when i would put the clutch in to **** into the next gear, the car would slow down to ~30mph. Then when i would try and keep a good speed, the front brakes started to smell. when i stopped, the front drivers side brake was smoking.
since then, i replaced the rotor, pads, and caliper and bled the brakes.
this problem is still occurring. the brake pedal is VERY firm. it seems to only happen after abour 5-6 minutes of driving. anybody heard of this?
Old Apr 30, 2007 | 10:14 AM
94eh2's Avatar
Default Re: brand new caliper locking up (g2_teg_)
sound like the piston in the caliper is seizing or getting stuck try a different caliper
Old Apr 30, 2007 | 11:33 AM
g2_teg_'s Avatar
Default Re: brand new caliper locking up (305accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord &raquo;</TD></TR><TR><TD CLASS="quote">sound like the piston in the caliper is seizing or getting stuck try a different caliper</TD></TR></TABLE>
well its a brand new caliper. i already replaced the caliper with the one im using now.
Old Apr 30, 2007 | 12:27 PM
seachunk2's Avatar
Replace the rubber hoses that connect to the caliber. If they're old they are probably rotted out inside and the mung is clogging up the caliber. I had that happening to a taurus, kept replacing the caiber, bleed, new pads & the caliber would fail WAY sooner than it should.
Old Apr 30, 2007 | 12:57 PM
matt da jdm junkie's Avatar
lube on the slides lol...lube
fordmike1980
14
Jun 13, 2018 07:52 AM
blkdoutteg
Suspension & Brakes
12
Aug 31, 2015 04:35 AM
type-r-frm-da-808
Suspension & Brakes
Feb 7, 2013 09:38 AM
goldfinger93030
Sep 19, 2010 07:33 PM
