HELP! 99-00 Front-End Conversion on a 97' Hatch
Old Apr 30, 2007 | 08:26 AM
Uncle Jesse's Avatar
Default HELP! 99-00 Front-End Conversion on a 97' Hatch
Hey everyone,
I'm having an issue fiting this 99-00 SiR front-bumper on my 97' hatch. I think I know what the fitment issues are so I was wondering if anyone could shed some light on this issue.
I was thinking all I have to do is put alittle notch in the bumper for it to fit over the mounting surface.
Thank you to anyone in advance.
Old Apr 30, 2007 | 08:30 AM
mikeycivic's Avatar
Default Re: HELP! 99-00 Front-End Conversion on a 97' Hatch (jdm_8)
do you have 99-00 fenders and hood ?
Old Apr 30, 2007 | 08:47 AM
Default Re: HELP! 99-00 Front-End Conversion on a 97' Hatch (mikeycivic)
Oh yes, I have the complete front-end. Fenders, Hood, Lights, Bumper, Grille.
Everything.
Old Apr 30, 2007 | 08:48 AM
I was always told I would never need a rad-support from a 99-00 and I dont think i do.
Old Apr 30, 2007 | 08:50 AM
turbociviccoupe's Avatar
you can either notch the bumper or grind the lip on the mount. but you grind it your gonna have to paint it so it dont rust
Old Apr 30, 2007 | 09:25 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: HELP! 99-00 Front-End Conversion on a 97' Hatch (turbociviccoupe)
You can grind the bumper itself or the radiator support where it doesnt line up. You can use a dremel or a makita grinder.
Or swap out the radiator support, but whatever.
Old Apr 30, 2007 | 09:50 AM
MiX's Avatar
MiX
just put a slit in the bumper and be done with it
Old Apr 30, 2007 | 10:32 AM
Default Re: (MiX)
Thanks everyone ! I think that notching the bumper is probably the best idea.
Old Apr 30, 2007 | 10:34 AM
ek4_b16a's Avatar
Default Re: (jdm_8)
i think that if you do that to the bumper, you might have to do it to the grill too...
Old Apr 30, 2007 | 11:43 AM
Default Re: (ek4_b16a)
Im almost positive I will have to drill the same size hole right next to it. They have the marking laied out already.
Old Apr 30, 2007 | 03:40 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_8 &raquo;</TD></TR><TR><TD CLASS="quote">I was always told I would never need a rad-support from a 99-00 and I dont think i do. </TD></TR></TABLE>
You don't need it... you can beat the crap out of it to make it fit. But yes, it would help fitment if you replaced it. I've said this before, and every once in awhile people try to tell me that it will fit with no modification.
I've posted these photos before.
Not my car though, I like my '98 front.
Old Apr 30, 2007 | 04:54 PM
dao_yaj's Avatar
force it in that what we did
Old Apr 30, 2007 | 05:28 PM
Ek Forever y0!
Default Re: (dao_yaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dao_yaj &raquo;</TD></TR><TR><TD CLASS="quote">force it in that what we did</TD></TR></TABLE>
Yeah, just push the plastic through the metal.
Old Apr 30, 2007 | 05:40 PM
mr. goodwrench's Avatar
just take a razor and cut the bumper to fit it in. i installed my front like two days ago. although im in the process of getting a carbon fiber hood.
Old Apr 30, 2007 | 05:47 PM
mr_nemesis2003's Avatar
Don't know if this helps, but i was running into the same problem so what i did was get a hammer and bend those tabs. Got the job done. I did not want to cut the plastic, and if i ever decide to go back i'll bend it back into place.
Old Apr 30, 2007 | 05:51 PM
once the grill goes on the cut will be cover by it
Old Apr 30, 2007 | 06:56 PM
Default Re: (mr. goodwrench)
Its crazy, I never thought that everyone else would run into the same problem I have. I think that cutting the plastic is probably the best idea. I dont want to damage any of the metal, and yes the grill is going to cover the area that is notched.
thanks guys, keep up the post.
Old May 2, 2007 | 10:26 AM
hmtcrxsir's Avatar
Default Re: (jdm_8)
dremel it off
Old May 2, 2007 | 10:41 AM
Genuine Rolla's Avatar
cutting the plastic would be the best way to go man.
OGI8UUP
Jun 28, 2007 09:51 PM
matraca0997
Jun 19, 2007 02:15 PM
vtec25
Jul 28, 2006 12:31 AM
LifeOnFire
Jul 22, 2004 10:10 PM
sponjah
Apr 21, 2003 12:41 PM
