boost gauge wireing
Just a quick question. Im trying to wire my boost gauge up to a 12v power source and was wondering where was the best way or best place to put the wire to so i can get that power? just so you guys know or if i didn't write this well enough, i already have the boost gauge T'd into the FPR and have the ground wire grounded to the car i need to know where i can get the POWER to it lol. thanks all for your help.
The battery + terminal has power. You can directly hook it up there like amp wires lol. or you can hook it up to your ignition wire. I believe you can look at the chart on the fuse panel cover underneath your steering column to the left. So when you turn your car on, you have power to it. Turn it off, it goes off.
ok so am i like jamming this wire into the fuse or am i cutting and soldering it to another wire. any pics? that could be easiest or would be easiest for me. if it matters or if you didn't know i have a 5th gen base. thanks for your response
Do a search on yahoo for splicing wires. You can also do the fuse box hook up also. But if you're really new and just want to see if you can get power to the boost gauge // checking to see if its working, hook up the 12v to the + terminal on the battery n ground the black wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien »</TD></TR><TR><TD CLASS="quote">i have three gauges...all of which i have sliced the power together and ran it to the fuse box. which is what you said which is sufficent.</TD></TR></TABLE>
x2
pull fuse out, wrap wire around one metal end, shove that sum'bish back in there
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainy City »</TD></TR><TR><TD CLASS="quote">The battery + terminal has power. You can directly hook it up there like amp wires lol. or you can hook it up to your ignition wire. I believe you can look at the chart on the fuse panel cover underneath your steering column to the left. So when you turn your car on, you have power to it. Turn it off, it goes off.
I have my boost gauge backlight spliced into my parking lights, so when my lights are on, my gauge is on. Otherwise the heat from the bulb during the day makes the needle stick. (on mine)
My A/f gauge is spliced into my ignition wire.
</TD></TR></TABLE>I have my boost gauge backlight spliced into my parking lights, so when my lights are on, my gauge is on. Otherwise the heat from the bulb during the day makes the needle stick. (on mine)
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IIVIIoOkY »</TD></TR><TR><TD CLASS="quote">if it wont mess with anything in my car then ill do it lol.</TD></TR></TABLE>
nope
nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien »</TD></TR><TR><TD CLASS="quote">that doing a bit much when you could just run it down to the fuse box..</TD></TR></TABLE>
Parking lights have a fuse too
Benjithx
Dec 15, 2004 12:40 PM
