how can you tell the differences between si and integra brakes?
the rotors are the same size but the caliper/piston assembly is different.
Integras will stop a tad better.
well im buying some si brake setup (rear) and i just want to make sure they are the right ones. Here is a pic.
Modified by Civicman86 at 8:29 PM 4/29/2007
As long as I dont have to take out any more Metal Gears
i believe the rears are the same, for Si and integra. The only diff would be the e brake cables
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">i believe the rears are the same, for Si and integra. The only diff would be the e brake cables</TD></TR></TABLE>
Correct
Correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Correct</TD></TR></TABLE>
On all FAQ threads though, they say the SI setup is lighter than the integra setup (integra setup is 7lbs heavier than the stock drums, and the SI setup is lighter than the stock drum setup). Is this the difference in the trailing arms?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 »</TD></TR><TR><TD CLASS="quote">
The knuckles I think might be differen't too.
I know the ebrake cable are the same they have the same part number. I found this out when buying new cables for my Si
The rear brakes are all the same. Same trailing arms.
The rear brakes are all the same. Same trailing arms.</TD></TR></TABLE>
Correct!
Correct!
ocular
May 29, 2008 01:44 PM
delslowhonda
May 17, 2006 01:35 AM
