how take off fuel filter off 92 vx bubble?
I'm trying to replace the fuel filter on my civic but dont know what parts to take off. Does any one have any diagram of how to take off a fuel filter?
Modified by 92EGBUBBLEBACK at 6:28 PM 4/29/2007
Well, the fuel filter is a black canister on the firewall that has a hard fuel line with a ring connector (it'll be a big brass fitting with a bolt through it), and then another one coming out the bottom.
Take off the top ring connector, and wrap it in a rag. Then take off the bottom one, wrap it in a rag.
Then remove the bolts holding the fuel filter to the firewall.
Taahhhdaaaaahhhh!
Taahhhdaaaaahhhh!
Wow guys cmon. haha give him a step by step guide.
1. open your gas cap to relieve some pressure, though when you unscrew the hose it'll still shoot out a lil.
2. located the fuel filter. I hope you know what this is since you're chanigng one.
3. grab a couple box wrenches i believe it was 14?
4. unscrew the brackets/bolts
5. unscrew the hose, i even took it out from the end that went to the Intake Manifold
6. Throw away the old canister and put the new one in.
7. Mine I bought was a fram so it didn't perfectly fit so I used zip ties for 1 bolt
8. Tighten everything back up but not too tight you strip stuff
9. Start the car
9. Start the car
