so installing a fuel pump...
Old Apr 29, 2007 | 01:54 PM
fatboyslim44's Avatar
Default so installing a fuel pump...
well i'm installing my fuel pump today and was wondering if there was any
way i can make it easier to install the next time around... the only thing i can
think of is cutting the floor and weld in a piece of sheet metal with a door so i can
access the top of the tank without ever having to drop it again...
just wanted to know if this is too over the top or a good idea...
thanks...
Old Apr 29, 2007 | 03:44 PM
EF_LSVtec's Avatar
Default Re: so installing a fuel pump... (fatboyslim44)
Just drop the tank. Honda did their R&D so you don't have to...
Old Apr 29, 2007 | 04:08 PM
Bjorn20's Avatar
why would you have to drop the tank at all????? theres an access panel under the back seat that leads right to the fuel pump
Old Apr 29, 2007 | 04:11 PM
msinsky14's Avatar
Default Re: so installing a fuel pump... (Bjorn20)
thats what I'm like...
Old Apr 29, 2007 | 04:41 PM
uberhaulin's Avatar
its impossible to get it out threw that panel..gotta drop the tank
Old Apr 29, 2007 | 04:45 PM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">why would you have to drop the tank at all????? theres an access panel under the back seat that leads right to the fuel pump
Go ahead and try replacing your fuel pump through that little plate under the back seat...Good luck to you.
Oh, and if don't feel like taking the seat out, you have the gas cap that's easily accessible through a square metal door..by key or a pull up lever next to the hatch release. Try getting your fuel pump out that way too...
Modified by EF_LSVtec at 6:13 PM 4/29/2007
Old Apr 29, 2007 | 05:00 PM
uberhaulin's Avatar
Default Re: so installing a fuel pump... (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">Go ahead and try replacing your fuel pump through that little plate under the back seat...Good luck to you.</TD></TR></TABLE>
thats what i said
Old Apr 29, 2007 | 07:34 PM
mahatma's Avatar
people have installed the access panel successfully.
that's kind of a 'glass is half empty' approach though. get a good fuel pump: oem or a real walbro and hopefully you won't be replacing it a lot anyway.
it's fun dropping the tank anyway, right?
black_integra
May 19, 2012 09:00 AM
Joeyt426
Aug 1, 2006 01:55 PM
accordredliner
Feb 26, 2006 02:41 AM
trooper0641
Jul 13, 2005 08:21 PM
sleepin91teg
Jun 5, 2005 10:02 AM
