Cant get tie fod on??????!!!HELP ME!!
I cant get the tie rod nut on the tie rod. Everytime i try to wrench it the tie rod just goes around witht he nut. There is nothing for me to hold it with so that i can tighten the nut? What do i do?
Modified by yoffer at 1:34 PM 4/29/2007
try a big pair of channel locks and squeeze the outer tie rod and the knuckle together and try to tighten it. also you can Pry the tie rod down with a pry bar and try to tighten it. when you squeeze the tie-rod into the tapered hole it'll tighten up and won't spin and you'll be able to tighten the castle nut on. good luck man
