another b16 build, just with a sazdasl twist
Old Apr 28, 2007 | 04:53 PM
sazdasl's Avatar
Default another b16 build, just with a sazdasl twist
Well I have been working on my ed7 hatch for about 4 months now. Hopefully I will be turning the key on it soon. It will be my autocrosser/DD so max power was not a goal.
mods are a
b16a
hks cat back
K&N filter in stock box(looking to keep throttle response)
dc 4-1
high flow cat
255lph pump
chipped pr3 ecu
progressive springs for b series swap
b&m short throw shifter
IM crossmember/eg radiator
finnaly on the ground
the rotas
roll bar :D
all that is left is finish installing the radiator, battery(could someone post pictures of where the + and - cables go?), valve cover gasket, 1 heater hose, fuilds and hope she starts!....too bad it is rent pay check
Old Apr 28, 2007 | 05:04 PM
Stefndogg's Avatar
Default Re: another b16 build, just with a sazdasl twist (sazdasl)
is that a crx roll bar...that thing doesnt fit for ****
Old Apr 28, 2007 | 05:52 PM
Crx Jimmy's Avatar
Default Re: another b16 build, just with a sazdasl twist (Stefndogg)
you swapped the motor and cant fugure out where the battery cables go
Old Apr 28, 2007 | 06:27 PM
sazdasl's Avatar
you would think the roll bar is kinda messedup but actually it still meets SCCA specs :D
yeah what can i say its the simple things that seem to be holding me up. Well i know the positive goes to the fuse box and the starter, but the negative...does it just get grounded?
Old Apr 28, 2007 | 07:52 PM
msinsky14's Avatar
Default Re: (sazdasl)
negative gets grounded on metal, will not work if theres any paint over it
Old Apr 28, 2007 | 11:05 PM
Under Con. CrX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sazdasl &raquo;</TD></TR><TR><TD CLASS="quote">you would think the roll bar is kinda messedup but actually it still meets SCCA specs :D
yeah what can i say its the simple things that seem to be holding me up. Well i know the positive goes to the fuse box and the starter, but the negative...does it just get grounded?</TD></TR></TABLE>
it is usualy grounded to the tranny
Old Apr 29, 2007 | 06:29 AM
sazdasl's Avatar
sweet thanks guys...i bought this car as just a shell and it was missing alot of things. I wish I had taken a picture of the wireing mess that it had
Old Apr 29, 2007 | 11:16 AM
EFM_ookie's Avatar
nice DA teggy dohc molding
Old Apr 29, 2007 | 12:40 PM
Bejita's Avatar
Default Re: (89_Mangina_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_Mangina_SI &raquo;</TD></TR><TR><TD CLASS="quote">nice DA teggy dohc molding </TD></TR></TABLE>
lol
Global688
Jul 6, 2007 01:59 PM
RACEPAK
Aug 24, 2006 10:16 PM
DOHC Vtec TSIT
Apr 12, 2006 09:24 AM
Kyles ej1
19
Sep 30, 2005 12:01 PM
j_max420
May 17, 2004 07:40 AM
