Does my 98 Civic HX have ABS?
You can look for an ABS modulator in the engine compartment (box w/ the 4 brake lines coming out of it) or if it's the original cluster you can look on the cluster for an ABS light. If you can't tell if it's on the cluster shine a flash light on it, you'll see all the dummy lights clear as day.
My guess is no because it's a lesser model, but I could be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">the 96-00 civics (from what i know) that came with abs are only 4 door civic ex's.</TD></TR></TABLE>
No, that is incorrect.
For '96-00, EX 4drs had ABS standard, but ABS was optional for certain years in EX 2dr, LX 4dr, and GX 4dr trims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Even the Si's didn't come with it. Well it was a option though...</TD></TR></TABLE>
ABS was not an option for the Si in the US. It was standard on the SiR in Canada.
