EGR valve situo.
Old Apr 28, 2007 | 12:19 PM
white99CF's Avatar
Default EGR valve situo.
hey guys i have a 91 accord f22a4 and i have a big question my car continues to accelerate once my feet are removed from the gas and clutch meanin the car should decelerate , but this car if im at low rpm 1800 or so n like 4 the car continues to accelerate with the intake open without my foot on the gas.......
would this have to do wit my egr valve????????????
Old Apr 28, 2007 | 12:34 PM
GhostAccord's Avatar
Default Re: EGR valve situo. (white99CF)
Have you ever replaced the EGR ? Do you have any mods/engine swaps? Records of routine maintenance that has been done recently? That info could be more helpful in the long run.
Check for a vacuum leak. when you pop the hood with the engine running can you hear a hiss from anywere other than the end of the intake? Could be that your throttle cable or throttle valve (butterfly) is gummed up and not able to close all the way. Are you handy with fix'n things? This could be as simple as checking your throttle cable ensuring that it is free from dirt and able to rotate and slid properly. If that's not it try removing the intake tube from your throttle body and give it a few good shots of carb/throttle body cleaner while your car is running. This will clean out some of the gunk (carbon & oil - tar like substance that gets built up around the throttle plate/butterfly.
Old Apr 28, 2007 | 12:56 PM
white99CF's Avatar
Default Re: EGR valve situo. (GhostAccord)
its a f22a4 intake exhaust ngk wires and plugs and ive done the carb cleaner thing a few times and problem still exist also when it does this it does throw a code dont kno which one and how to check but yea it does and yes im very handy at fixing things i do 90% of the work on my car unless tranny or brakes LMAO
Old Apr 29, 2007 | 09:47 AM
gulfview's Avatar
Is your gas pedal binding on something?
How strong is your throttle cable return spring?
smeags
10
Jul 20, 2013 10:22 AM
fatpride111
Dec 5, 2008 05:57 AM
fandirabbani08
Honda Civic (2006 - 2015)
15
Nov 11, 2006 03:44 PM
your username here
14
Jul 5, 2006 05:19 PM
n3v3tz
Mar 5, 2004 08:38 AM
