Damn CEL light wont go away
Old Apr 27, 2007 | 09:15 PM
S2k Hybrid's Avatar
Default Damn CEL wont go away
Besides all the crappy luck I been having lately with my car (check previous threads), now my map sensor is possibly done
Some highlights...
*I had an idling problem or should I say still have an idling problem, some say its the IACV and some have no clue.
*I cleaned and installed 2 IACV's and the idling still continued.
*Had new plugs, wires, cap, rotor, fuel filter, air filter, and pcv installed and still no luck
*I installed a OEM timing belt very recently which was needed and I thought it would fix the idling but still no luck
Now my car is giving me whiplash cause of the map sensor. Quick question, is it possible it was the map sensor all along instead of the IACV? Also, am I supposed to pull off the negative terminal before installing another map sensor? My neighbor told me I can fry it if I dont.
Old Apr 27, 2007 | 09:18 PM
S2k Hybrid's Avatar
Default Re: Damn CEL wont go away (S2k Hybrid)
I said CEL light, what a dum dum I am
Old Apr 28, 2007 | 12:32 PM
S2k Hybrid's Avatar
Can the MAP sensor be cleaned? If so with what?
I removed my old map sensor and installed another and still same problem. When I turn the key to on position, the CEL does not turn on but after I start the car it boggs a little and then the CEL turns on. I already checked the code a few times, its the map for sure
Old Apr 28, 2007 | 12:47 PM
S2k Hybrid's Avatar
anyone?
Old Apr 28, 2007 | 01:57 PM
S2k Hybrid's Avatar
a bunch of views but no responses
Old Apr 28, 2007 | 02:06 PM
pdiggitydogg's Avatar
a bad iacv will cause instant-on throttle
thats about all the help i can give you
Old Apr 28, 2007 | 03:40 PM
S2k Hybrid's Avatar
Default Re: (pdiggitydogg)
But it still has code 3 (map sensor)
im gonna try my friends map sensor, hopefully 3's a charm
Benny Bao
Oct 14, 2014 11:47 AM
§95HATCH§
Apr 6, 2009 12:40 PM
Tyler Con
Oct 10, 2007 11:53 PM
jay-d-em
Sep 7, 2006 05:07 PM
dizzyek
May 17, 2006 09:38 AM
