idle at 1200 rpm's
Old Apr 27, 2007 | 08:41 PM
tpatt's Avatar
Default idle at 1200 rpm's
I have a 95 prelude and I just changed the radiator and fixed a leaking hose. I have bled the coolant twice. It now idles at about 2k when cold and while warming up, goes to around 1k, and when warm moves to about 1300 rpm. Any idea what's going on? Thank you.
Old Apr 28, 2007 | 04:27 AM
thaiswirls's Avatar
Default Re: idle at 1200 rpm's (tpatt)
are your coolant levels ok?
Old Apr 28, 2007 | 04:46 AM
ProjectTib's Avatar
try bleeding your coolant a little more and then check your level... also make sure you dont have any vaccuum leaks
Old Apr 28, 2007 | 05:21 AM
thaiswirls's Avatar
Default Re: (ProjectTib)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectTib &raquo;</TD></TR><TR><TD CLASS="quote">try bleeding your coolant a little more and then check your level... also make sure you dont have any vaccuum leaks</TD></TR></TABLE>
vaccum leak would lower the idle wouldn't it? lack of air to the motor correct? It seems as tho his idle is high so that would mean its getting too much air. Or do i have the right concept wrong thinkin? lol
SpEeDyX
Jul 5, 2009 10:59 AM
BlueLude84
Sep 18, 2008 09:30 AM
-HONDA-
Sep 4, 2007 12:00 PM
FatAndFurious
Oct 28, 2006 02:02 AM
chronodyne28
May 3, 2004 12:07 PM
