I'm sure this has been asked before... 92-95 LX Cluster into CX Hatch
Old Apr 27, 2007 | 08:07 PM
Dasfinc's Avatar
Default I'm sure this has been asked before... 92-95 LX Cluster into CX Hatch
Tach works, Lights work, Speedo doesn't work correctly, and Cruise Control light is now acting as a shift light.... What needs to be done to correct the Speedo and Cruise control?
Old Apr 27, 2007 | 09:06 PM
BlueIntegraBoy's Avatar
Default Re: I'm sure this has been asked before... 92-95 LX Cluster into CX Hatch (Dasfinc)
How does the speedo not work correctly? The cruise control and shift light are on the same plug (same circuit). Disconnect the shift light plug from the cluster, since you don't have cruise control anyways.
Old Apr 27, 2007 | 10:03 PM
Techy's Avatar
Default Re: I'm sure this has been asked before... 92-95 LX Cluster into CX Hatch (BlueIntegraBoy)
was the speedo workin correctly on your original cluster? If so then I say bad cluster.
Old Apr 28, 2007 | 08:40 AM
Dasfinc's Avatar
Speedo was working on origional cluster, My current cluster came STRAIGHT out of a operational car. Speedo only goes up to like 20-30mph and kinda bounces *Which makes me thinks this is a sensor issue and not a bad cluster*
Old Apr 28, 2007 | 08:42 AM
Techy's Avatar
well just for the hell of it, tryyour old cluster again. If it does the same, bad sensor, if it works, your new cluster is bad.
Old Apr 28, 2007 | 12:26 PM
Dasfinc's Avatar
Default Re: (Techy)
I'm thinking its because it came from a LX Sedan with a diffrent motor, and diffrent Chassis length *Sedan* Anyone have any other ideas?
Old Apr 28, 2007 | 12:38 PM
Bense's Avatar
nobody is going to help you until further diagnose where the problem lies.
All there going to tell you to do is "check the wiring, check the sensor, try another one"
3 things
1. bad cluster
2. bad vss
3. bad wiring
if you changed your trans, check vss
if you changed your wiring, check wiring
but since you changed your gauge, check it.
just remove the speedo gauge from dx cluster and put it on the lx cluster. Problem solved.
cx and dx clusters are worthless anyways
Old Apr 28, 2007 | 12:53 PM
Techy's Avatar
Default Re: (Bense)
it from an an LX don't mean squat. I had an LX cluster in my EX Coupe after my coupe's speedo went out and it worked perfectly. It sounds like the speedo in your cluster is bad.
Old Apr 28, 2007 | 01:04 PM
Dasfinc's Avatar
Default Re: (Bense)
You can???
Old Apr 28, 2007 | 01:07 PM
Bense's Avatar
i've done it before, so yes
Old Apr 28, 2007 | 01:10 PM
Dasfinc's Avatar
Default Re: (Bense)
Bitchen, Thank you!
Old cluster worked perfect, and no wiring changed, so I guess the Speedo is toast....
Old Apr 28, 2007 | 01:24 PM
Bense's Avatar
hope you have access to a #2 phillips
it's very easy, no writeup required.
Old Apr 28, 2007 | 04:22 PM
Targa250R's Avatar
be professional
The speedometer heads on '92-95 Civics frequently fail - I used to deal with them a lot. It is not a problem with your car if the old speedo worked correctly. It is not a compatibility problem because gauge clusters are plug-and-play.
Just swap your old speedo unit into your new cluster. I usually recommend this anyway to keep the original odometer.
russlan44
Sep 24, 2009 08:40 PM
Lucid_Dream
12
Mar 6, 2007 03:03 PM
E-lude78
Jun 5, 2003 01:20 PM
^Sammy]!.
13
Mar 5, 2003 06:09 PM
carlos
10
Oct 15, 2002 08:57 PM
