Idle GOIN CRAZY AGAIN!!!!
idles crazy
when i turn on it idle low or high after i drive off n come to a stop its start to idle high n low........between 2k n 1k....its not the fitv because i dont got one(00 si throttle body).....its most likely the IACV......but this would be the third one thats gotten messed up in bout 2-3 months
heres the setup maybe can help u help me.....
b18b1 block
b16 head of a 00 SI including manifold throttlebody.
also i have no CEL except for a 23 (knock sensor)
and no vac. leeks
thanks for ur help
b18b1 block
and no vac. leeks
thanks for ur help
Check your coolant and try bleeding it (which I believe is just cracking the cap 1 click when its cold and driving it around until its warmed up).
Hondaman45628
Jul 10, 2013 07:23 PM
AllMTRWH0R3
Aug 4, 2004 03:40 PM
