ecu fuse keeps burning out... wtf!
Old Apr 27, 2007 | 07:05 PM
flipsyde's Avatar
Default ecu fuse keeps burning out... wtf!
alright i got of work today and started driving home. i came to a stop light and the car just shut of on me. pushed it to the side, called some friends, and started diagnosing. checked for spark.. none! checked for fuel... none! swapped out main relay... nothing! finally... checked ecu fuse under the hood and seen that it was burnt. replaced it and it started right up. i drove home and as soon as i pulled into the garage it shut of again. i rechecked the ecu fuse and same thing... blown again... wtf!
stock ls motor had been in my civic for about a year and never had any problems like this till now.
has anyone ever experienced this problem and found out what the problem was???
Old Apr 27, 2007 | 07:20 PM
flipsyde's Avatar
anyone???
Old Apr 27, 2007 | 08:06 PM
maynards_ek's Avatar
Default Re: (flipsyde)
I had a wire that was exposed, and it kept grounding out and blowing the fuse. You might check your wiring, and make sure you are using the proper fuse. (amperage)
Old Apr 27, 2007 | 08:38 PM
flipsyde's Avatar
Default Re: (maynards_ek)
ill check for any exposed wired tomorrow. thanks for the reply!
Old Apr 27, 2007 | 09:08 PM
ke98248's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek &raquo;</TD></TR><TR><TD CLASS="quote">I had a wire that was exposed, and it kept grounding out and blowing the fuse. You might check your wiring, and make sure you are using the proper fuse. (amperage)</TD></TR></TABLE>
sounds about right
Old Apr 27, 2007 | 09:28 PM
flipsyde's Avatar
could my main relay cause the fuse to blow??
Old Apr 28, 2007 | 08:25 AM
flipsyde's Avatar
ttt!
Old Apr 29, 2007 | 03:43 PM
flipsyde's Avatar
update:
after inspecting my wireharness today i found that extended o2 harness was hanging over my header. it burnt through the black/yellow wire on the engine harness side of the o2 plug, so the wires were exposed, and it probablly grounded when it touched the header.
i started it and let it idle for about 10 minutes and restarted it again later for about 5 minutes. now i have to take it out for a test spin. i dont want to end up getting stuck again. hopefully that was the problem.
Old Apr 29, 2007 | 03:46 PM
flipsyde's Avatar
sensor voltage wire grounding on my header downpipe. would that cause ecu fuse to blow???
just want to get a little bit of backup before i take the car out for a test spin and risk the possibility of getting stuck.
Old Apr 30, 2007 | 08:55 PM
flipsyde's Avatar
well drove the car to work and back today, so i guess that was the problem.
Old Apr 30, 2007 | 08:57 PM
deadline's Avatar
do u have a msd ignition hooked up ?
Old May 1, 2007 | 08:35 PM
flipsyde's Avatar
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">do u have a msd ignition hooked up ?</TD></TR></TABLE>
no msd...
Joshb152
Oct 9, 2015 09:10 PM
ej1 assasin
Oct 30, 2006 07:56 AM
TORQUE MONSTER
Apr 21, 2003 01:41 PM
Metal_SOL
Sep 8, 2002 08:31 AM
chuckd05
Nov 6, 2001 08:13 AM
