93 del sol burning oil..... BADLY
Old Apr 27, 2007 | 01:55 PM
brianandlydz's Avatar
Default 93 del sol burning oil..... BADLY
I recently aquired a 93 del sol s (d15b7...5-speed) that had a burned exhaust valve in #4 cylinder.... replaced burned valve, reground old valves just enough to remove excess carbon build-up and seat the valves, installed new valve stem seals, and put motor back together.... car did not appear to be burning oil or smoking (actually ran pretty well on just 3 cylinders)..... now burning oil and smoking badly... 150-155 psi compression across the board... please help... don't want to hop up (well, not right now anyway) just want it to stop smoking... runs very smooth even though it smokes like a chimney.....
Old Apr 27, 2007 | 02:02 PM
Flatland2D's Avatar
So it wasn't smoking before you worked on it? Are you 100% sure the new seals were installed properly?
Old Apr 27, 2007 | 02:11 PM
Default Re: (Flatland2D)
Installed them per Hayne's manual instructions
Old Apr 27, 2007 | 11:07 PM
Flatland2D's Avatar
Default Re: (brianandlydz)
Sorry I can't be of more help. I'm not an expert on this stuff, but, the only way I can see oil getting in the cylinders from what you did is the valve seals. I guess it could be something with the head?
SolTrain92
Aug 8, 2015 06:15 AM
93 del sol si2
165
May 19, 2013 07:04 PM
nickeynick
Jun 15, 2011 11:27 PM
c_riggan
13
Oct 7, 2005 02:51 AM
akuma_delsol
Apr 25, 2005 05:18 PM
