New Pads on Old Rotors?
Old May 29, 2002 | 04:44 PM
Flux's Avatar
Default New Pads on Old Rotors?
Is it okay to use new pads on my current OEM rotors? Is there something I would need to do to the rotors?
Old May 29, 2002 | 04:55 PM
nsxtcjr's Avatar
New User
Default Re: New Pads on Old Rotors? (Flux)
Yes.
No.
Old May 29, 2002 | 04:56 PM
Flux's Avatar
Default Re: New Pads on Old Rotors? (nsxtcjr)
That was easy. Thanks.
Old May 29, 2002 | 06:30 PM
type r 01-1063's Avatar
No.
Well actually if the rotors feel like their uneven, or small dips (run your finger along the rotor than you can tell) than you need to get the rotor resurfaced or replaced. Other than that you should be ok
Old May 29, 2002 | 07:00 PM
Wet Nudl's Avatar
New User
Default Re: New Pads on Old Rotors? (type r 01-1063)
What about the rings on the rotors? Are they consider dips or uneveness?
Old May 29, 2002 | 07:13 PM
nsxtcjr's Avatar
New User
Default Re: New Pads on Old Rotors? (typeRP)
By "rings", I assume you're talking about concentric grooves in the surface. As long as these are moderate, they're no problem; the pads will quickly "bed in", wearing so that the surface of the pad conforms with those grooves.
If they're unusually severe - more like gouges - then the rotor may require resurfacing or replacement, as indicated above. But that's pretty rare on a street car.
Old May 29, 2002 | 07:19 PM
Wet Nudl's Avatar
New User
Yes, they are the concentric rings I see when I stand next to the car while looking into the wheels. Can't tell if they are bad/deep or not but will try it later. Need to put on my Hawk pads, both front and rear. The front rotors are just 2 weeks old but the rear rotors are still the original rotors and the car has 13k miles now with 2 days track event. I toasted the front rotors (warped) after the 2nd day but I can't tell if the rear needs to be replaced too.
Old May 29, 2002 | 07:26 PM
nsxtcjr's Avatar
New User
Rotors generally need to be replaced (a) if they're warped (as you already understand), or (b) if they're cracked or gouged (normally easily visible), or (c) if they're thinner than the spec; they wear down after a while.
With the number of miles you've got, I doubt that the rears need replacing. Track use puts almost all the strain on the front brakes, not the rear.
93_hatchie
Suspension & Brakes
Dec 11, 2008 03:59 PM
mr tl
Sep 20, 2002 08:22 PM
andrew n
Jun 18, 2002 12:04 PM
illusion
Apr 10, 2002 09:31 AM
mr tl
Dec 5, 2001 07:30 PM
