Suspension Flanges Where?
Old Apr 27, 2007 | 02:27 AM
skr33t_rac3r's Avatar
Default Suspension Flanges Where?
Im looking for a place that sells these:
thanks guys
Old Apr 27, 2007 | 06:33 AM
LSEGHATCH's Avatar
Default Re: Suspension Flanges Where? (skr33t_rac3r)
The peice on the right just looks like pipe cut to size.
Old Apr 29, 2007 | 08:32 PM
Top Ramen's Avatar
Default Re: Suspension Flanges Where? (LSEGHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">The peice on the right just looks like pipe cut to size.</TD></TR></TABLE>
I agree - doesn't look like anything more than a pipe section.
For the other, it looks pretty simple to make with a hole saw and a drill press.
Old Apr 30, 2007 | 05:42 PM
i dont have any machining tools and the piece is not apipe cut to size, you would have to see a piece like that to un dertsnad it acctually has a backside to it
Old Apr 30, 2007 | 06:03 PM
tony1's Avatar
I doubt you're going to find those, you're going to have to make them yourself.
Old Apr 30, 2007 | 09:07 PM
Top Ramen's Avatar
Default Re: (skr33t_rac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skr33t_rac3r &raquo;</TD></TR><TR><TD CLASS="quote">i the piece is not apipe cut to size, you would have to see a piece like that to un dertsnad it acctually has a backside to it </TD></TR></TABLE>
So its a pipe section with a bottom welded on?
Old May 2, 2007 | 08:24 PM
racer_X_123's Avatar
Default Re: (Top Ramen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">So its a pipe section with a bottom welded on?</TD></TR></TABLE>
Yes, acutally when i built my X-brace for the trun of my EK i took a pipe and a washer that had the same OD and welded that on... It is really easy for that part.
As for the other one. I dont see why you would need to go all the way around the shock tower like that. It seems for the sake of fabrication that it would be smartest to just build half a circle.
Racer_X_123
Old May 3, 2007 | 04:58 PM
turboteener's Avatar
Banned
This is the welding and fabrication section, make the pieces.
Old May 3, 2007 | 05:28 PM
Top Ramen's Avatar
Default Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener &raquo;</TD></TR><TR><TD CLASS="quote">This is the welding and fabrication section, make the pieces.</TD></TR></TABLE>
That's pretty much what I said in my first post, just a bit nicer. ; )
Old May 3, 2007 | 05:38 PM
JDMCRX's Avatar
Bandsaw and a hole saw
Im going to be making some soon for strut tower braces
GraphiteMW
Mar 23, 2008 08:49 AM
RCautoworks
Welding / Fabrication
13
Mar 20, 2006 07:14 PM
denske
10
Jan 22, 2006 03:36 PM
Toda Party
Jan 2, 2006 02:28 PM
Boost Addict
Jun 20, 2004 01:06 AM
