check engine light.
I have a 99 gsr with ls/vtec swap. also a tuned p28. the check engine light came on and i ran the code with a stock gsr ecu. it threw a throttle position sensor, after replacing check engine light still on. Ran the codes again and it threw a crank position sensor, but my car still runs. I tried disconnecting the battery with the obd1 ecu but still no luck.maybe t is just the obd2 throwing false codes but if so why is the check engine light on with the tuned p28? anything to trouble shoot will help.
P.S. I am new to this sight but have some knowledge and experience. Willing to help with any problems I am familar with and know about.
Modified by HondaHero at 9:50 PM 4/28/2007
sovled my own problem. i was runnin codes with a gsr ecu, but running ls/vtec. so it was throwing the crank sensor code because the ecu cant read a ls motor, because the crank has a longer stroke. real problem is when i pt in a new tps sensor i didnt adjust it right so after fine tuning everything went right.
Modified by HondaHero at 9:51 PM 4/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHero »</TD></TR><TR><TD CLASS="quote">sovled my own problem. i was runnin codes with a gsr ecu, but running ls/vtech. so it was throwing the crank sensor code because the ecu cant read a ls motor, because the crank has a longer stroke. real problem is when i pit in a new tps sensor i didnt adjust it right so after fine tuning everything went right.</TD></TR></TABLE>
that still makes no sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT »</TD></TR><TR><TD CLASS="quote">Its VTEC not vtech.</TD></TR></TABLE>
i was going to post the same quote---plz if u so called know honda/acura use the right term. vtech is on toys and house phones.
how does it not make sense, i was using a gsr ecu to run codes on a ls. Because the ls crank has a different stroke the ecu was throwing another code. I realized this when i used my friends itr ecu and all it threw was a tps code and that was what is really wrong.. and damn mybad for sayin VTECH i was diff. typin to fast and not really thinkin, had a college exam. Sorry everybody who read my post and saw that **** its embarrassing. I shoulndt of even posted anything when i was in a hurry, cz **** like that point thank for pointin it out.
kaoss_11
Sep 10, 2006 04:14 PM
