distributor question
Old Apr 26, 2007 | 06:28 PM
thedudefromjerz's Avatar
Default distributor question
Can I just take the old distributor off and put the new one one? Or do I have to set the timing and arrange pistons. Is it a hard job? Ive done work on cars before but ive never set timing. Im a plumber not a auto mechanic so if anyone can help ill apreciate it. Thanks
Old Apr 26, 2007 | 06:43 PM
Crx Jimmy's Avatar
Default Re: distributor question (thedudefromjerz)
yes you can just unplug it and put it on, it does not matter where the engine is, in its cycle. The distributor will only go on one way the key is offset so it only goes on the proper way, In a perfect world you would use a timing light after to check the timing, but I have just slapped them on and adjusted it by how the engine sounds while the engine is running. move it back and forth and find the sweet spot its not perfect but im usually within 1 degree of spec by doing that.
Old Apr 26, 2007 | 09:25 PM
gotbooost's Avatar
it would be wise to mark the position of the old one with a sharpie or marker so you have a point of reference. That way even without a timing light you'll be sure that you're close to your "original spec."
Old Apr 26, 2007 | 09:32 PM
RCautoworks's Avatar
Default Re: (gotbooost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotbooost &raquo;</TD></TR><TR><TD CLASS="quote">it would be wise to mark the position of the old one with a sharpie or marker so you have a point of reference. That way even without a timing light you'll be sure that you're close to your "original spec."</TD></TR></TABLE>
But how would you line up the new one, since there is no mark on that distributor ?
When you get the distributor in, try not to turn to. Try to eye the post up
Old Apr 26, 2007 | 09:53 PM
welfarepc's Avatar
Default Re: (RCautoworks)
easy, you make the mark on the edge of the dizzy, so when you throw the new one on, you align the edge to the mark
done
Old Apr 26, 2007 | 09:57 PM
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">easy, you make the mark on the edge of the dizzy, so when you throw the new one on, you align the edge to the mark
done </TD></TR></TABLE>
Point taken, I just use my timing gun
the_dxB16
Mar 7, 2008 09:39 PM
91smashbox
Feb 11, 2008 01:33 PM
brusk13
Jan 11, 2006 07:01 PM
krazn
Feb 22, 2004 11:11 AM
H23ludedude
Feb 11, 2003 11:12 AM
