gas cap problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 »</TD></TR><TR><TD CLASS="quote">ok i have a buddy with a 89 crx with a b18a1 obd0
his problem is when he takes off his gas cap it sprays out fuel
what could be the problem</TD></TR></TABLE>
Demonic gas tank?
Hmmm...... I have no idea what it's called but there's a little hinged flap that stays shut unless you insert the gas nozzle.... maybe this is failing somehow and not containing the pressure in the system?
Demonic gas tank?
that thing you plugged coming out of the firewall for the charcoal canister is suppost to be a vent, route a hose that goes fromthat to where the charcoal canister vented to its right under your shock tower thers ahole
Mine does this too! My charcoal canister is still in the car though. I know the pressure isn't supposed to be that much but I don't know what to do about it.
After searching it seems that if you weren't to have any pressure then there would be a problem. Our fuel systems are pressurized therefore causing the hissssss.
it is more than a hissssssss it is spraying fuel out of the gas cap when you take it off. the fuel pressure is whay to high to
yeng_vaj85
Oct 2, 2009 10:26 PM
