Bosch In Tank Fuel Pickup
Old Apr 26, 2007 | 05:18 PM
Big Teggie's Avatar
Default Bosch In Tank Fuel Pickup
I decided to ditch my old Walbro in tank pump, and now I am using a Bosch 044 fuel pump. I didn't want to sump the tank , but might in the near future.
Do you guys think I will have any pickup problems under acceleration or deceleration?
The sock sits in the original location, and the pump is going to be mounted about 1.5' of line away. The pickup line is -8 and the return is -6. The oem tank baffling is untouched.
Thanks
Old Apr 26, 2007 | 05:43 PM
vaporboy12's Avatar
Default Re: Bosch In Tank Fuel Pickup (Big Teggie)
looks something what i ran last year. i had no problems with it like that
Old Apr 27, 2007 | 04:30 AM
Big Teggie's Avatar
Default Re: Bosch In Tank Fuel Pickup (vaporboy12)
Ok, Thanks.
Old Apr 27, 2007 | 04:58 AM
White Smoke's Avatar
i my honda
Global Mod
Curious, how mush did it run you for all those fittings?
Old Apr 27, 2007 | 11:21 AM
1FSTHATCH's Avatar
Default Re: Bosch In Tank Fuel Pickup (White Smoke)
I run the exact same setup..Works fine, but you never wanna run low fuel in the tank..With sump setups you can get away with running lower fuel levels, but i try to keep the tank atleast 1/4 tank always..
Old Apr 27, 2007 | 01:12 PM
Big Teggie's Avatar
Default Re: Bosch In Tank Fuel Pickup (1FSTHATCH)
I had most of the fittings, I just needed to purchase the bulkheads which were around $15 I think.
I plan to keep about 5 gallons in the tank, maybe more to add weight.
Old Apr 27, 2007 | 03:22 PM
2 0 3's Avatar
Looks Good!!
Old Apr 27, 2007 | 04:05 PM
Adriano's Avatar
Default Re: Bosch In Tank Fuel Pickup (2 0 3)
I have that same set-up but without the filter/sock. Been running it for the past 3 years, no issues. That setup with a bosch 044 and 1000cc should be enough fuel for 660-670whp.
Adriano
Old Dec 22, 2007 | 11:23 AM
SwappedTURBOegg's Avatar
Im looking for a pickup filter that would hook up to something like -10 hose cant find one anywhere i have been searching for hrs.
OP
did you run yours this way because you couldn't find one either?
Old Dec 22, 2007 | 12:04 PM
best i could find. http://www.atlltd.com/filters.htm
Old Dec 23, 2007 | 10:13 AM
scoop's Avatar
looks good
nick77538
Motorcycles
Jul 7, 2017 08:59 AM
Undergroundeg6
Jul 19, 2013 01:23 PM
slvrslepr
Aug 20, 2008 06:07 PM
91integraLSVTEC
Oct 26, 2003 07:52 PM
BLKCRX
Sep 12, 2003 08:14 AM
