Code 21 Troubleshooting
Old Apr 26, 2007 | 02:00 PM
DarkBB4's Avatar
Default Code 21 Troubleshooting
Whats a good list of things to do to fix this problem... Car won't even crank over
ELD: electronic load device
Modified by DarkBB4 at 1:01 PM 4/28/2007
Old Apr 26, 2007 | 05:01 PM
preludefien
Guest
Posts: n/a
Default Re: Code 21 Troubleshooting (DarkBB4)
correct me if im wrong but isnt that a vtec code.
Old Apr 26, 2007 | 05:59 PM
DarkBB4's Avatar
Default Re: Code 21 Troubleshooting (preludefien)
ELD-electronic Load Device
Old Apr 28, 2007 | 12:01 PM
DarkBB4's Avatar
bump for answers
Old Apr 28, 2007 | 02:16 PM
SteveoBA8's Avatar
My manual says code 21 is the vtec solenoid code and 20 is eld. Which do you need help diagnosing?
Old Apr 28, 2007 | 02:28 PM
DarkBB4's Avatar
Default Re: Code 21 Troubleshooting (SteveoBA8)
ooo ****, well see im kinda confused cause when i check the code, it blinks 2 LONG and then flashes REally quickly another one
so maybe it is code 20 ELD
Old Apr 28, 2007 | 04:50 PM
SteveoBA8's Avatar
2 long followed by 1 quick should be code 21. Give me some background, were you driving and all the sudden the cel lit up? You did a harness tuck correct? I would check all those connections.
Old Apr 28, 2007 | 05:59 PM
DarkBB4's Avatar
car hastn' started yet... its 2 long and then followed by a REALLY SHORT blink (like a flicker), (wayyy shorter then the average short blink (for 1))
Car just Clicks when ur try to crank it
Old Apr 29, 2007 | 06:44 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong but isnt that a vtec code.</TD></TR></TABLE>
good call chris
evan, the ELD is in the alternator, test for resistance between the plug and the ecu pin.
Old May 1, 2007 | 06:34 AM
DarkBB4's Avatar
Default Re: Code 21 Troubleshooting (mgags7)
thats random that the alternator was fucked up
i thought ELD was in the fuse box
I'm going to ADD all new 4 gauge grounds everywhere.. ithink that should fix it
i also noticed that when iremoved abs there are a lto of plugs on the harness that aren't plugged in... maybe im forgetting some
Old May 5, 2007 | 11:05 AM
DarkBB4's Avatar
Any other suggestions?
Old May 5, 2007 | 12:33 PM
92_VTEC_lude's Avatar
I got code 21 b4 and I cleaned the VTEC solenoid and it was gone for good
I am having code 20 (ELD) that I am trying to fix in my chipped P28 running ubderdata, I am trying to find that ELD relay which under the fuse box in the engine compartment of a 4th GEN JDM PRELUDE since I can not turn it off in uberdata.
remember to reset your ECU after clean the VTEC solenoid...
Old May 5, 2007 | 04:54 PM
squarepusher's Avatar
waht year / model lude you got?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">Any other suggestions?</TD></TR></TABLE>
Old May 5, 2007 | 04:56 PM
Default Re: Code 21 Troubleshooting (squarepusher)
20 is ELD
21 is VTEC solenoid.
21 wouldn't cause your car from starting, just would be a VTEC problem, u suer its not 20 ?
Old May 5, 2007 | 10:39 PM
zirac50's Avatar
when you turn the key and your only getting a click, that might be also a bad starter (or mybe bad battery connection). I remember my friend's car i used to hammer his starter to get it start.
Old May 7, 2007 | 10:58 AM
DarkBB4's Avatar
Default Re: Code 21 Troubleshooting (zirac50)
ive tried 2 starters.... its def code 20
ill post progress and pics on wednesday
thanks guys@!
Old May 7, 2007 | 03:06 PM
prelittlelude's Avatar
an ELD code won't keep the car from turning over. you should check all your grouds, especially from the motor to the batery and motor to body.
frankenstienEk
Dec 1, 2009 09:26 PM
97teg415
Jun 1, 2008 07:03 PM
dirtyrice
May 31, 2007 08:55 PM
drumminforev
25
Nov 11, 2006 09:19 PM
dreams190
Apr 1, 2005 07:03 AM
