i just got my car running but something is wrong
Old Apr 26, 2007 | 08:00 AM
freddysEF's Avatar
Default i just got my car running but something is wrong
i was driving my car and i notice that i can pass 3500 RPM's it starts to jerk, and i have two codes and the numbers are 16, 17. can someone tell me why i cant rev higher???
i have a 1990 civic hatchback (stock motor)
Old Apr 26, 2007 | 08:05 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: i just got my car running but something is wrong (freddysEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freddysEF &raquo;</TD></TR><TR><TD CLASS="quote">i was driving my car and i notice that i can pass 3500 RPM's it starts to jerk, and i have two codes and the numbers are 16, 17. can someone tell me why i cant rev higher???
i have a 1990 civic hatchback (stock motor) </TD></TR></TABLE>
Code 16: Fuel injectors
Code 17: VSS (Vehicle Speed sensor)
This can be found in the FAQ: https://honda-tech.com/zerothread/1710584
Clear up those codes first before you try anything else. For the code 16 you need to check your fuel injectors, if they are good, then it's a problem with the wiring going to them. Code 17, either your speedometer cable is broken or needs to be pushed back into the housing on top of the transmission. Otherwise, if your speedometer works fine, try resetting your ECU to see if it goes away.
Old Apr 26, 2007 | 08:08 AM
freddysEF's Avatar
Default Re: i just got my car running but something is wrong (wiZCo)
thanks that helps, but why can i rev higher then 3500
Old Apr 26, 2007 | 08:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freddysEF &raquo;</TD></TR><TR><TD CLASS="quote">thanks that helps, but why can i rev higher then 3500</TD></TR></TABLE>
Because when your car throws codes, that's BAD. Your car is most likely not revving over 3500RPM because it's in "limp mode". This happens because there is something wrong (you're throwing codes) and the ECU does this to protect the engine from blowing up. Fix the codes.
Old Apr 26, 2007 | 08:16 AM
Creator's Avatar
probably because your injectors are shot
freddysEF's Avatar
ohhh ok i understand thanks a lot, ill fix it right away
Old Apr 26, 2007 | 11:43 AM
freddysEF's Avatar
alright i fix both problems, for the injector it was just a wire was mix with a different one. then for the speed sensor, the cable broke so i just got a new one so now my car is running good so thanks for all the help
Old Apr 26, 2007 | 11:44 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freddysEF &raquo;</TD></TR><TR><TD CLASS="quote">alright i fix both problems, for the injector it was just a wire was mix with a different one. then for the speed sensor, the cable broke so i just got a new one so now my car is running good so thanks for all the help</TD></TR></TABLE>
Glad to hear it, come back when you need help again .
Metal Head
Sep 1, 2008 08:12 AM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
Discontained
10
Sep 24, 2006 10:16 PM
sitrucjr
May 22, 2004 10:47 PM
Herminator
Jun 28, 2003 03:45 AM
