Anyone run this tupe of injector resistor
I have always seen people use the box type resistors anyone use this method..
http://homemadeturbo.com/tech_....html
I would just be carefull when using the clay style of resistors. Yes they are cheaply courced from any Radio Shack... but I have seen them fail. The conector is a single piece of wire that if bent back and forth a few times will snap off. try it with a paperclip before using them. Bend the paperclip back and forth a few times and see how easily it breaks. The wire from those clay resistors is a thiner gauge wire than mast paperclips.
We have use the aluminum housing resistors with actual conectors with no problems... spend a few extra dollars to do it right rather than loosing a motor because you are to cheap to spend the extra couple dollars. if you want more info shoot me a PM.
kholmes
Apr 13, 2005 09:49 PM
Boosted LS
Jul 9, 2003 08:52 AM
