SOHC VTEC or LS Swap?
Old Apr 26, 2007 | 05:46 AM
88EFRacer's Avatar
Default SOHC VTEC or LS Swap?
i need some help. i got a 88 ef civic hatch dx. i want to do a engine and tranny swap but i dont know which should pick. i got a choice between a sohc vtec or a ls motor. im looking for one to give me a lot of power and maybe add a turbo down the line. if anyone could help me on which is better and maybe a good setup, that'll be great, thanks
Old Apr 26, 2007 | 06:08 AM
91r-e-xsi's Avatar
Default Re: SOHC VTEC or LS Swap? (88EFRacer)
I would go with the b18. I had a sohc zc (non-vtec) and the differance was amazing. Its a better swap in my opinion. It will cost more because you need mounts and shift linkage, but i got the whole setup for $1,500.
Old Apr 26, 2007 | 06:10 AM
CRX Toad's Avatar
All depends on how much work you want to do? Is this going to be a street only car? How much money do you want to spend?
Old Apr 26, 2007 | 06:14 AM
Xemu's Avatar
Go sohc and then boost it.Cost ya about the same as an ls swap and thenyou can kill ls swaps all day long!!
SIred91's Avatar
Rainman
Default Re: SOHC VTEC or LS Swap? (CRX Toad)
There is some great info and everything you will need to know on a B swap up in the FAQ at the top of the page.
I would do the LS. Much better platform to start with and a great motor to boost, with lots of aftermarket support.
If your on a tight budget, stay with the D.
It sounds like, either way, you are going to switch to 0BD1, so get the B.
Old Apr 26, 2007 | 06:29 AM
Creator's Avatar
on the LS, costs a little more but you get more
ohh yea and if you find an engine without a tranny get a b16 cable tranny the match up is great
Old Apr 26, 2007 | 07:45 AM
mini-me-power's Avatar
Stay with the D, try to find a cheap Z6 or Y8 and get some vitaras from FJT, and eagle rods. get a custom turbo kit, boost 6-7 PSI and get a good tune.
Turbo D
Old Apr 26, 2007 | 10:37 AM
turbodcivic510's Avatar
if you get the LS swap, youll be satisfied for maybe a month then you boost it and make like 250+whp. and youll have a h killer
but im a firm believer in turbo D's so i duno there
Old Apr 26, 2007 | 08:19 PM
91r-e-xsi's Avatar
Default Re: SOHC VTEC or LS Swap? (Creator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator &raquo;</TD></TR><TR><TD CLASS="quote"> on the LS, costs a little more but you get more
ohh yea and if you find an engine without a tranny get a b16 cable tranny the match up is great </TD></TR></TABLE>
I would agree that is what i am running and it pulls a hell of a lot harder than my brothers old ls crx did.
OneSloEk9
Jan 29, 2011 10:24 AM
BUBBLE BOY
Sep 22, 2006 06:07 PM
boostedpleasure
Jul 11, 2006 06:12 AM
leblanc3
Mar 25, 2005 03:18 AM
Quik89Si
Jun 15, 2002 09:05 AM
