Tial 35mm Wastegate clearance? (Tried Search)
My question is:
Will the tial 35mm Wastegate clear the hood in a 2001 GSR with a drag manifold and no boost controller? (IE: No fittings hooked up to the top port?)
I know this has been covered before, but I couldn't find anything.
Re: Tial 35mm Wastegate clearance? (ThePunk)
if you have no fitting on the top port, you should be fine......
when you eventually have the EBC, then you can use a small brass fittings like the one on top of the FMU for the vaccum source...
