Reving?
Old Apr 25, 2007 | 10:30 PM
team 15's Avatar
Default Reving?
My 97 civic throws code 7 which is the tps sensor. So i bought a use throttle body from hap recycling w/ all the sensors. I install it in. I start the engine and now it keeps on reving before it did not rev w/ the old throttle body but now it rev. There 's no code anymore but till rev. Can it be the throttle body I bought that is no good?
Old Apr 25, 2007 | 10:59 PM
Mr.EM1_EK's Avatar
Default Re: Reving? (team 15)
did you adjust your idle. turn that little screw on the tb see if that helps
Old Apr 27, 2007 | 09:48 AM
team 15's Avatar
Default Re: Reving? (Mr.EM1_EK)
I did, but still idle to low.
Old Apr 27, 2007 | 10:33 AM
Blk00EJ8's Avatar
Was two threads really necessary for this?
https://honda-tech.com/zerothread/1967029
It sounds like a vacuum leak. Do you have a gasket on there?
Jeeptech
May 19, 2017 08:12 PM
Andrew Ryan P
Mar 20, 2017 07:48 PM
phelpsj2
Nov 3, 2011 02:35 PM
95_red_dc
Sep 11, 2006 09:47 PM
PowderB16
Jul 16, 2004 08:34 PM
