98 civic coupe interior light HELP
Old Apr 25, 2007 | 08:30 PM
honda genome
Guest
Posts: n/a
Default 98 civic coupe interior light HELP
Ok so i installed a new deck today into my car.....before this the interior light set to the middle position would turn on when door was open, but now it doesnt turn on when door is open, but can be turned on automatically when i switch it to the furthest position.....anyone know what is going on?
Also my honda remote doesnt work anymore to lock/unlock car keyless entry....
wierd anyone have this problem?
Old Apr 25, 2007 | 08:56 PM
Mr.EM1_EK's Avatar
Default Re: 98 civic coupe interior light HELP (Honda Genome)
are your fuses good
Old Apr 25, 2007 | 09:26 PM
honda genome
Guest
Posts: n/a
if a fuse weren't good, then it wouldnt turn on at all...
Old Apr 25, 2007 | 09:38 PM
EK_B's Avatar
You have to reattach your old radio to your deck via a reverse harness. The interior light as well as keyless entry is in the stock radio.
Old Apr 25, 2007 | 10:31 PM
Mr.EM1_EK's Avatar
Default Re: (EK_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Genome &raquo;</TD></TR><TR><TD CLASS="quote">if a fuse weren't good, then it wouldnt turn on at all...</TD></TR></TABLE>
duh was not thinking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B &raquo;</TD></TR><TR><TD CLASS="quote">You have to reattach your old radio to your deck via a reverse harness. The interior light as well as keyless entry is in the stock radio.</TD></TR></TABLE>
iyeah you said it. i did read something on that before
Old Apr 25, 2007 | 10:55 PM
smileycvc's Avatar
Default Re: (Mr.EM1_EK)
you can also get an installation harness from cartoys or something. I remeber in my first honda when i pulled the deck out there was a stock one behind it. I was like WTF? If you get the right installation harness though it will work without having the stock deck.
Old Apr 25, 2007 | 10:57 PM
Eran's Avatar
HT White Ops
Didn't you already post this and didn't I already answer this?
Old Apr 26, 2007 | 04:16 PM
honda genome
Guest
Posts: n/a
i read somewhere that you can jump the wires...is this true? has anyone did this before?
thanks
Old Apr 26, 2007 | 05:27 PM
honda genome
Guest
Posts: n/a
ok so i stuck the green plug into the original ddeck and i got the light to work, but how do i get the keyless entry to work now? which wires do i jump???
Old Apr 26, 2007 | 05:38 PM
honda genome
Guest
Posts: n/a
nvm i got the solution right her....http://www.installdr.com/InstallDocs...PDF/466013.pdf
Old Apr 26, 2007 | 07:38 PM
honda genome
Guest
Posts: n/a
for those wondering, the light and keyless entry are hooked up to a module inside the stock deck. to over ride this, you must have the green plug, plugged into the deck, and have constant power (orange) wire, wired up to the back ot stock deck as well as the ground. simply, you can just tap into the wires and use female conectors to plug into the pins of the stock deck, and use a honda harness to complete the installation of the aftermarket deck, which I installed beind the cup holders on the bottom.
Hope this helps for anyone that comes across this annoyance.
redtegy
11
Feb 1, 2013 06:13 PM
traxxasx
Mar 12, 2008 07:17 PM
rhgindc
19
Apr 7, 2007 04:06 AM
wishingiam
Mar 17, 2005 09:06 PM
CRiSP
Sep 25, 2003 03:16 PM
