steady high idle w/ no codes
Old Apr 25, 2007 | 06:49 PM
Tatakai's Avatar
Default steady high idle w/ no codes
recent ls/vtec build, and my idle runs really high @ about 2k steady. about 1.9-2 when cold and 1.6-7 when warm. my concern is the timing possibly being off by a tooth on my belt, however i don't have access to a timing light until tomarrow. 99% sure it's not a vacuum leak, and i'm not throwing any codes. it also has seems to be a _little_ hesitant to accelerating, i only noticed it when trying out a little WOT for the first time since the build, another reason i think the timing could be off.
Old Apr 25, 2007 | 09:43 PM
Tatakai's Avatar
Default Re: steady high idle w/ no codes (Tatakai)
bump
Old Apr 25, 2007 | 10:41 PM
smileycvc's Avatar
dont drive it then until you get the timing light. a whole tooth doesnt seem like much but it could cause some serious problems. I would put the motor back at tdc then check your cam timing again. that way you dont have to wait till you get a timing light.
polishedturd
May 8, 2008 06:51 PM
92ehatch
Jul 28, 2007 05:40 PM
NoVALude
Nov 20, 2006 11:02 AM
handa
Apr 11, 2005 10:36 AM
cjohnson_2
Mar 6, 2004 12:29 PM
