Brakes question
Old Apr 25, 2007 | 05:58 PM
spoolin_teg's Avatar
Default Brakes question
What rear brakes are you guys using for your 94-01 integras? Meaning, what calipers and rotors. I just wanna get rid of the tiny *** back brakes. Thanks guys
Old Apr 25, 2007 | 06:31 PM
slowly slipping away's Avatar
Default Re: Brakes question (spoolin_teg)
I upgraded my rears with Brembo drilled rotors, axxis pads and stainless steel brake lines oh and some Motul brake fluid..work great on the comute and on the track!
upgrading the rear caliper itself can be rather expensive, and since your front brakes do more "work" it would be more practical to upgrade the front calipers- unless your ballin like that-
Old Apr 25, 2007 | 09:39 PM
Brad's Avatar
fastbrakes.com has a rear kit that uses a larger rotor. It fills out the inside of the wheel nicely. Also, I think ep3 rear brakes can work with some modification.
Old Apr 25, 2007 | 09:42 PM
I was looking at the fastbrakes setup as well- has anyone used that setup? things to say about it?
Old Apr 25, 2007 | 10:48 PM
RaceMyGhost's Avatar
Default Re: (slowly slipping away)
why do you want to ugrade your rears? what setup are you running in the front?
Old Apr 26, 2007 | 05:31 AM
cappykd's Avatar
PM BrakeExpert here on the forums. He has ITR caliper front and rear upgrades much cheaper than fastbrakes. You could do your fronts and rears for less then the fastbrakes kit. Also you won't have to worry about screwing up your brake bias!
Old Apr 26, 2007 | 05:22 PM
Default Re: (RaceMyGhost)
thanks guys.
Jim Dan
Honda Civic (2001 - 2005)
Apr 17, 2013 12:42 PM
sjbmx
Jun 11, 2008 03:41 AM
babzog
May 22, 2008 09:49 PM
JDMlyfestyle
13
Mar 22, 2004 11:04 PM
Jason
Jun 30, 2001 04:43 PM
