Brakes question
Brakes question
What rear brakes are you guys using for your 94-01 integras? Meaning, what calipers and rotors. I just wanna get rid of the tiny *** back brakes. Thanks guys
Re: Brakes question (spoolin_teg)
I upgraded my rears with Brembo drilled rotors, axxis pads and stainless steel brake lines oh and some Motul brake fluid..work great on the comute and on the track!
upgrading the rear caliper itself can be rather expensive, and since your front brakes do more "work" it would be more practical to upgrade the front calipers- unless your ballin like that-
fastbrakes.com has a rear kit that uses a larger rotor. It fills out the inside of the wheel nicely. Also, I think ep3 rear brakes can work with some modification.
Re: (slowly slipping away)
PM BrakeExpert here on the forums. He has ITR caliper front and rear upgrades much cheaper than fastbrakes. You could do your fronts and rears for less then the fastbrakes kit. Also you won't have to worry about screwing up your brake bias!
JDMlyfestyle
13
03-22-2004 11:04 PM
