B18A/B into EG Hatch
Old Apr 25, 2007 | 01:17 PM
bodiby's Avatar
Default B18A/B into EG Hatch
I have searched but come up with hundreds of results.
I have a 93 civic hatch that i would like to put a B18A or B into with plans of eventually going turbo. I am putting together a list of all needed parts. I have a 91 integra that has a bad motor. I haven't checked the engine on the teg yet so I am not sure how much is usable. However, I want to keep as much as I can use from the teg.
Here is my list so far:
Tranny - b series hydro tranny
Mounts - depends on donor car
ECU - a 94-95 pr4.
Electric - 4 wire oxygen sensor? knock sensor?
Axles - 90-93 integra axles - got that!
Linkage - 94 up integra linkage
Upper Radiator Hose - 94 integra ls.
Lower Radiator Hose - 94 del sol vtec
Throttle Cable - 90 integra ls or 94 integra ls. which one?
Air Conditioning - 94-95 Del Sol vtec ac bracket
Distributor - 92-95 integra b18a or b18b (OBD1)
Am I missing anything?
Old Apr 25, 2007 | 01:47 PM
blk_EK's Avatar
Default Re: B18A/B into EG Hatch (bodiby)
engine harness
Old Apr 25, 2007 | 02:11 PM
bodiby's Avatar
duh!!! ok - engine harness from OBD1 B18a / b
Old Apr 25, 2007 | 02:44 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bodiby &raquo;</TD></TR><TR><TD CLASS="quote">
ECU - a 94-95 pr4. --- PR4 I belive is 92-93 integra ECU, P74 is the 94-95 B18b ECU
Electric - 4 wire oxygen sensor? knock sensor? --- no knock sensor needed if your going with OBD-1
Throttle Cable - 90 integra ls or 94 integra ls. which one? ---You can use any integra throttle cable to work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bodiby &raquo;</TD></TR><TR><TD CLASS="quote">duh!!! ok - engine harness from OBD1 B18a / b</TD></TR></TABLE>
Actually, your factory D16 92-95 engine harness will work just fine How do I know? I used mine and didn't have any problems at all
Old Apr 25, 2007 | 08:41 PM
bodiby's Avatar
Sweet - one less thing to worry about!
dx95civic
Apr 29, 2020 08:03 PM
B16ACivichtch
Oct 28, 2006 11:44 AM
ShagPower
Sep 2, 2005 07:29 AM
newbiedelsol
Aug 14, 2005 02:21 AM
The G2 Racer
May 1, 2004 09:20 PM
