SRS Light
My SRS Light have been on for a year now and I never bothered to take a look at it and see what the problem is...I was wondering how you can take the SRS light without cutting the wire
It's in a 94 Civic Si Hatch
thanks in advance
thanks in advance
I had an 95 CX CDM and didnt come with the air bags, long story short I switch the CDM cluster to USDM EX and the SRS light was on like wtf tape was ok, but I remove the old cluster case(not sure its called that) and switch it with the USDM SRS was still on but I didnt care work for me.
here is the link about reseting you SRS light. I need to do the same thing eventually
https://honda-tech.com/zerothread?id=264288-
u could take out the fuse in the bottom fuse box. it should b the one that is covered with a yellow thing. try that out cause i removed my whole airbag system and i forgot to take out that fuse and the light was still on, untill i took that out.
